Squealing belt issue - Team Camaro Tech
 2Likes
  • 1 Post By carcrazy615
  • 1 Post By dyno jonn
post #1 of 15 (permalink) Old Jul 25th, 18, 02:43 PM Thread Starter
Tony
I have aftermarket Classic Auto Air installed on my 350 in my 68 convertible.
The AC belt wraps around the water pump pully which is being turned by the crankshaft (with the alternator)
Whenever I turn on my AC, the compressor kicks on and the squealing is very loud and embarrassing. I tried to tighten the belt but then the fan would barely turn. I put the AC in so I could use it and now I cannot use it.
Tony
Follow my current Camaro project builds...
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
bondora68 is offline
post #2 of 15 (permalink) Old Jul 25th, 18, 03:25 PM
Vega$69's Avatar
Re: Squealing belt issue
How would tightening the belt stop the fan from moving?
Post a pic of your belt/pulley set up
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 15 (permalink) Old Jul 26th, 18, 04:30 AM
ray
Compressor may be locked up.
Pacecarjeff likes this.
carcrazy615 is online now
post #4 of 15 (permalink) Old Jul 26th, 18, 04:53 AM
Bill
Agreed, it sounds like a bad compressor front bearing or a compressor clutch issue.
arocars is offline
post #5 of 15 (permalink) Old Jul 26th, 18, 05:35 AM
Chris
As John suggests, a photo would help. Most A/C setups require the belt wrap around a good portion of the A/C compressor pulley to eliminate slip there. Is your belt wrapping around the A/C pulley or is the belt for the A/C compressor pulley just touching a small portion of the side of the pulley? You can run a water pump with minimal belt contact, but not a heavy load A/C compressor.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #6 of 15 (permalink) Old Jul 26th, 18, 11:35 AM Thread Starter
Tony
Here are some pics of my set up...
ID:	219851   Click image for larger version
ID:	219853   Click image for larger version
ID:	219857   Click image for larger version
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #7 of 15 (permalink) Old Jul 26th, 18, 11:39 AM Thread Starter
Tony
Pics
ID:	219861   Click image for larger version
ID:	219863   Click image for larger version
ID:	219867   Click image for larger version
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #8 of 15 (permalink) Old Jul 26th, 18, 01:23 PM
Jon
No doubt the alternator belt is slipping because all the power to run the air and the alternator and water pump is going through just one belt. If you could run the a/c compressor belt around the crank pulley, that would take a lot of the load off of the alternator belt. Just my opinion. Take it for what it's worth.
Jon N
dyno jonn is online now
post #9 of 15 (permalink) Old Jul 26th, 18, 06:10 PM Thread Starter
Tony
Here is my set-up:
AC compressor has its own belt to the water pump. The water pump and alternator share a belt that loops around crankshaft, the power steering has it's own belt around the crankshaft.
How should I change this set up?
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #10 of 15 (permalink) Old Jul 26th, 18, 06:29 PM
Jon
You would need to have a lower pulley that allows the ac belt to be driven off of the crankshaft as well as going around the water pump pulley. No doubt that would solve the squealing problem. I can't see the bottom pulley to see whether it has three groves or not. No matter, it needs that third groove to run the ac belt.
Jon N
post #11 of 15 (permalink) Old Jul 27th, 18, 05:42 AM
Chris
If you've not already done so, I'd take a look at the AIM for your '68 and use the prescribed belt configuration for running an a/c compressor.
ctcz28 is offline
post #12 of 15 (permalink) Old Jul 27th, 18, 07:01 AM Thread Starter
Tony
Thank you to all!
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #13 of 15 (permalink) Old Jul 27th, 18, 10:45 AM
Jeff
When you add AC you need to add another grove using an adapter pulley for the Crank.
The A/C compressor belt must also go around the Crankshaft, and The water pump.
that will solve your problem...
Pacecarjeff is offline
post #14 of 15 (permalink) Old Jul 27th, 18, 11:28 AM
Jon
CRG listing for 1968 pulleys ~ pdf
camaros.org/pdf/pulleys-68
Jon N
post #15 of 15 (permalink) Old Jul 28th, 18, 03:09 PM Thread Starter
Tony
Yes! That is what I ended up doing. I got a longer belt and went around the crank and the water pump. I already had the extra groove on the crank pulley, I just put the AC belt on wrong. It works great now!
Thanks guys!
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
