Radiator Shroud?? - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 23rd, 18, 07:43 PM Thread Starter
Robert
Radiator Shroud??
I see more and more cars with double electric fans, and no water pump mounted fan, and no cooling shroud, with aluminum radiators, do they cool the engine as well as a regular fan with the shroud. Canít you have the electric fans, and no water pump mounted fan and a radiator shroud and do as well. Just wondering why I see so many classic cars without a water pump mounted fan.
Rls8836 is offline
post #2 of 6 (permalink) Old Aug 23rd, 18, 08:02 PM
Vega$69's Avatar
Re: Radiator Shroud??
When you install Electric fans the mechanical fan is eliminated
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 6 (permalink) Old Aug 24th, 18, 03:29 AM
kevin
I tried this set up first and it would not cool the engine. then went to a belt driven fan
flat tire is offline
post #4 of 6 (permalink) Old Aug 24th, 18, 07:03 PM Thread Starter
Robert
Vega$69, What I was wondering can you run a cooling shroud in conjunction with the electric fans? That was what I was wondering about. And why do people have the shrouds removed? Is this just recommended when running electric fans?
Rls8836 is offline
post #5 of 6 (permalink) Old Aug 25th, 18, 03:20 AM
The electric fans are usually mounted to a shroud, itís just not the factory shroud.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #6 of 6 (permalink) Old Aug 26th, 18, 07:59 PM
Sean
Iíve actually used my factory 68 shroud with a fan that fit inside the shroud, actually mounted it to the shroud. Fan was from a Cadillac with a transverse V8, it worked fine, I didnít care for the look too much but it looked stock. I had my reasons but I wanted it to look stock at any rate...lol.
I eventually changed it to a cleaner look, using a 90ís V6 Taurus shroud and fan, it worked great and was super quiet.
You really should use a shroud, It may work without one but wonít be anywhere near max efficiency.
Thatís why I like using a factory fan and shroud, the shroud is designed to flow air and the fans are efficient and quiet.
What I would avoid is a shroud like the one pictured above, those are just killing surface area with that flat panel. Basically the two flaps and the round openings are all you have for airflow. Terrible design. Easy to build, but thatís about it.
Sean
Franklin D. Roosevelt
68rs406 is offline
