Vintage air - Team Camaro Tech
 9Likes
  • 2 Post By Vega
  • 1 Post By Sosh67
  • 4 Post By Hostile-67
  • 1 Post By X-77 keith
post #1 of 11 (permalink) Old Sep 13th, 18, 06:36 AM Thread Starter
Apprentice
Vintage air
I'm sure its been covered here before but how difficult is it to install a Vintage air system on a Non-AC car?
lucy67 is offline
post #2 of 11 (permalink) Old Sep 13th, 18, 09:29 AM
Eric
Re: Vintage air
Depends on whether your car is in a build phase or if it's all put together. VA can be installed in either but much easier if apart. If I recall, you can specify if your kit is for an original AC or Non AC car as some parts and instructions are different in the two kits. That said, I found VA to be one of the best quality products (including comprehensive instructions) that I've dealt with. They also have a customer support and tech line that is very helpful. The challenging parts are getting everything in under the dash and through the firewall but the kit includes plates and equipment to help that. My only under hood issues were getting the right water pump (short vs long) to get pulleys lined up around the crank, alternator, water pump and AC compressor. Doable but may involve some trial and error and belt/pulley experimentation. When it's all done they work amazingly well.
EricO is offline
post #3 of 11 (permalink) Old Sep 13th, 18, 09:30 AM
Re: Vintage air
A lot of variables there including installerís skill set and tools etc. Have you downloaded and read the instructions?
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #4 of 11 (permalink) Old Sep 13th, 18, 09:36 AM
Vega$69's Avatar
Re: Vintage air
Installation is not difficult.
The hardest part is removing all of the original parts. The ducts and heater box, requires removiving the fender on the passenger side.
You will also need to remove the gauge cluster and center dash panel.
Like Don suggested download and read the instructions
130fe and wireboy355 like this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 11 (permalink) Old Sep 13th, 18, 01:00 PM
Keith
I'm installing one right now on a non A/C car.
In my case, I have a car that is going through a ground up restoration. So, I can get the fabrication and fittment done without any problems.
First determine if u want to use their standard ducts or OER/OEM.
They have kit 49306-VCL and 493067-LCA kits that adapt OER vents to their duct work.
This gives you a stock appearance. Much nicer than the ones they supply.
Additionally, you can use an orginal A/C control panel that they can mate up with. It gives a more stock appearance. They just swap out a circuit board.
You will have to remove your passenger fender, which is a headache. I recommend you do it with fender well attached.
You can opt to drill holes in your heater box cover. If you do this, you don't have to remove your fender. I did not like the Vintage air firewall plate. So, I drilled holes in the stock heater box. It looks better IMO.
Good luck!
wireboy355 likes this.
Sosh67 is offline
post #6 of 11 (permalink) Old Oct 20th, 18, 06:19 PM
Les
Like some have said, it’s easy as part of a full rebuild but pretty invasive for a built car. You have to decide if you are going to run the hoses through the firewall through the old heater box or up under the fender through the blower hole. I went through the blower hole to try and hide the hoses as much as possible.
Hostile-67 is offline
post #7 of 11 (permalink) Old Oct 21st, 18, 04:57 AM
DT
Donny
DT's Avatar
Re: Vintage air
The install is pretty straight forward. It can become a real PITA if you try and get fancy and run the hoses in the inner fender to hide them or through the kick panel, also the inline outlets on the firewall look great, however they can present more difficulty under the dash. So.... it really comes down to if you will follow the VA install instructions or not.
DT is offline
post #8 of 11 (permalink) Old Oct 26th, 18, 04:37 AM
Bruce
Re: Vintage air
I avoided a firewall connection and ran the hoses through the blower hole and under the fender. I got a 4 hole round fitting from VA from a Chevelle if I remember. Gives a clean firewall look. As the guys have said, read the directions a few times.
The Camaro Guy is offline
post #9 of 11 (permalink) Old Oct 26th, 18, 06:06 AM
keith
X-77 keith's Avatar
When they talk about tools, most are standard everyday tools with exception of a vacuum pump and the hose crimper. I did not want to spend the money on the crimper. I measured and marked my hoses where I wanted them. Then I went to a local hydraulic hose shop to get them crimped. With the angle if the VA compressor fittings the shop could not do it. The shop had some that had less of a bend that would fit in their machine. It worked great. If anyone knows of a economic hand crimper, that would be of great use. Other than that, I live my gen 4 system. I getting ready to buy one for my 66 el camino very soon.
X-77 keith
X-77 keith is offline
post #10 of 11 (permalink) Old Aug 22nd, 19, 02:43 AM Thread Starter
Apprentice
Re: Vintage air
thank you for all your great advice. I may tackle this during the winter when I have plenty of time. My car is a finished so there will be some disassembly to do I see. Thanks again . I'll post updates when the install begins.
lucy67 is offline
post #11 of 11 (permalink) Old Aug 22nd, 19, 05:06 AM
keith
X-77 keith's Avatar
You will not regret the update. It was 98 degrees and a heat index of 110 here last Friday. After about 20 minutes of driving I had to turn the fan down. Was getting cold in the car.
HawkX66 likes this.
X-77 keith
