1969 heater box and fan mounting - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 16th, 18, 10:10 AM Thread Starter
Hello all,
I'm still trying to mount my heater box and blower motor, and I have a few questions-
To begin with, it's a standard heater box, non-ac. I understand that to mount the external box to the firewall (actually attached to the internal heater box) I need some specialty strip caulk sealant (which goes around the perimeter of the heater box) and five fabric/rubber washers for the internal heater box screws. I can get the sealant at a local auto parts store, so my first question is the fabric washers - Any recommendations on what to use, and the size/thickness I need? As near as I can tell, the washers are to help with keeping the sealant from completely squishing out when the screws are tightened. The local hardware store has some thick-ish rubber washers for faucet repair, and I'm also considering making some from a sheet of 1/32" cork gasket material I have laying around. I can see Ricks has a kit for $8.50, am I just better off buying that?
Second, is there any sort of gasket or sealant used when attaching the blower motor to the heater box? I've looked and looked and it doesn't seem like it.
Any and all comments are welcome and appreciated, thank you in advance.
-Mark from MN
Locrian is offline
post #2 of 4 (permalink) Old Sep 16th, 18, 01:45 PM
keith
X-77 keith's Avatar
No sealer is required on the blower motor. I have never used the washers you are talking about. I'm sure others will chime in on it shortly.
X-77 keith
X-77 keith is offline
post #3 of 4 (permalink) Old Sep 16th, 18, 02:43 PM
Kevin
KevinW's Avatar
Re: 1969 heater box and fan mounting
Agree, no sealer for blower motor. For sealing the heater box to firewall, you want dum-dum putty (sold in box store as electrical box putty). Comes in a brick, just grab a chunk and roll it in your hand and make a snake then put the snake in the groove of the core cover.
I do not recall any fabric washers. I think it was just a dab of putty in the nut which sealed the hole as you tightened
Kevin
KevinW is online now
post #4 of 4 (permalink) Old Sep 17th, 18, 05:24 AM Thread Starter
Thank you for your help Keith and Kevin.
-Mark
Locrian is offline
