A/C Compressor horrible Squeal - Team Camaro Tech
 1Likes
  • 1 Post By parkbrau
post #1 of 8 (permalink) Old Sep 18th, 18, 09:06 AM Thread Starter
I rebuilt the factory A/C in my 68 a few years ago, and it recently started having a problem. It started only occasionally but is now constant. The A/C would be running for some time, then the A/C compressor would stop turning and make a loud squealing sound as the belt is slipping. Now it is very constant. I start the A/C, the compressor engages and runs normally for a couple minutes and the vents blow cold air then the compressor locks up. It has been suggested that the expansion valve is stuck open and liquid refrigerant is getting to the compressor, which obviously will not compress and causing the compressor to stop turning. Any way to prove this theory? The valve is cheap so I guess I could try it, but losing $100 of R12 on a blind test concerns me. The compressor, expansion valve, dryer, condeser and hoses were all replaced when I rebuilt it. The evaporator is original but I pressure tested it. It also has the original POA valve.
68RS/SS Convertible L48 (350/295 Powerglide)
daverichard is offline
post #2 of 8 (permalink) Old Sep 20th, 18, 06:33 AM Thread Starter
Re: A/C Compressor horrible Squeal
No A/C gurus out there? I am sure someone has an opinion!
post #3 of 8 (permalink) Old Sep 26th, 18, 12:42 PM Thread Starter
bump...
post #4 of 8 (permalink) Old Sep 26th, 18, 01:15 PM
Vega$69's Avatar
When the system is serviced the R12 should be recovered for reuse?
Vega$69 is offline
post #5 of 8 (permalink) Old Sep 26th, 18, 01:59 PM
Remove the belt and check the movement of the bearing itself on the clutch. Mine went on the daily driver this summer and you would have thought the engine was coming apart by the sound of it, awful squealing and grinding noises. If it is just the bearing, it's easily replaced.
Melrose RS is offline
post #6 of 8 (permalink) Old Sep 27th, 18, 08:32 AM Thread Starter
Clutch spins free. Also only squeals when the clutch is engaged and it takes a couple minutes after turning on the A/C for it to start making noise.
On the R12 issue, you can get a shop to recover the R12, but they cannot reinstall it. They are required to recycle it. I would rather not change to 134 if I don't have to as these old systems just don't cool as well when updated.
post #7 of 8 (permalink) Old Sep 27th, 18, 08:36 AM
parkbrau's Avatar
Try another clutch. The clutch will spin free until energized.
Petes L48 likes this.
parkbrau is offline
post #8 of 8 (permalink) Old Sep 27th, 18, 08:46 AM
Ed
Sounds like maybe a bad clutch or bearing once it gets hot.
ZEN357 is offline
