a/c switch question - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 25th, 18, 09:35 PM Thread Starter
Apprentice
domo
a/c switch question
I have a 69 camaro with original suitcase, an Old Air POA kit, a pressure switch (i believe it is binary). I am installing the correct Vintage air condenser with dryer. With be kool radiator/electric fans, do i need a trinary switch? If so does it get mounted in the dryer, or just replace the current one in the old air POA? I would like the fans to come on when the a/c is on and at the correct pressure, and also shut down on high/low pressure...thx!
chev69 is offline
post #2 of 8 (permalink) Old Nov 26th, 18, 04:17 AM
Re: a/c switch question
You can just trigger the fans with the compressor power line. Not as good as a trinary switch but done on a lot of installations. Either way you will need a fan controller with an AC input. I like the Entropy two speed controller or better yet the DCC PWM controller. Keeps the noise down versus the fans on at full speed.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 8 (permalink) Old Nov 26th, 18, 10:44 AM Thread Starter
Apprentice
domo
with these changes, i would still need a hi/low pressure switch correct? install it on POA or on new dryer?
i did read that switch needs to be installed somewhere in hi pressure liquid line...still learning this stuff!
chev69 is offline
post #4 of 8 (permalink) Old Nov 26th, 18, 02:39 PM
You still need a binary switch. I would put it on the dryer but itís been a while since Iíve messed with a POA valve. Hopefully an expert will reply. Are you converting to R134A?
dhutton is offline
post #5 of 8 (permalink) Old Nov 26th, 18, 05:28 PM Thread Starter
Apprentice
domo
right now the binary switch is on the POA between the evaporator and the compressor which is the low side, correct? what i have been reading is that it should be mounted in the hi pressure/temp liquid line between the compressor and the expansion valve, like on the dryer.
already runing 134a..
chev69 is offline
post #6 of 8 (permalink) Old Nov 26th, 18, 05:32 PM
Why donít you just leave it as it is and trigger your fans off the compressor. If it ainít broke, donít fix it....
dhutton is offline
post #7 of 8 (permalink) Old Nov 26th, 18, 06:32 PM Thread Starter
Apprentice
domo
unfortunately it is kind of broke...hi side hose blew, which leads me to believe there is no binary hi/low pressure switch on the system. the Old Air switch on the POA may be just a pressure cycling switch. The condenser is mounted with tubes vertically instead of horizontally and there is no dryer on system, so I dont really trust how the previous owner built the system. I met a guy at SEMA from Old Air who said to send him pics and call him to diagnose the problem, so that is my next step...learning as I go...will post what I find out...thx
chev69 is offline
post #8 of 8 (permalink) Old Nov 27th, 18, 07:44 PM Thread Starter
Apprentice
domo
found out that the switch on the POA valve is only a pressure cycling type to keep the evaporator from freezing up, so there was no hi/lo pressure switch on the system. I can continue to use it or change it out to a thermal switch. Need to add a trinary switch which also turns the fans on when needed...
chev69 is offline
