What brand Aluminum radiator fits best with no mods - Team Camaro Tech
 4Likes
  • 1 Post By The Camaro Guy
  • 3 Post By 68rs406
post #1 of 13 (permalink) Old Jan 18th, 19, 05:01 PM Thread Starter
Tom Anderson
Hi guys
I getting ready to buy a aluminum radiator for the car and wound to hear which ones fits best from the guys who have them
socal_tom is offline
post #2 of 13 (permalink) Old Jan 19th, 19, 02:59 AM
kevin
Re: What brand Aluminum radiator fits best with no mods
I used champion. direct fit with no modifications. It keeps my 9.9-1 engine 175-180* on the hottest days
flat tire is offline
post #3 of 13 (permalink) Old Jan 19th, 19, 04:36 AM
Bruce
I would have your original one re cored unless you want a different size. Many guys feel it is better than aluminum. Of course they are cheaper and lighter.
kookykrispy likes this.
The Camaro Guy is offline
post #4 of 13 (permalink) Old Jan 19th, 19, 05:22 AM
Champion here as well....This is one place where BIGGER IS BETTER IMO...go 4 core.
68 Camaro~LSx ~all motor
post #5 of 13 (permalink) Old Jan 19th, 19, 06:18 AM
Chris Casperson
Send a message via AIM to Ccass
Most of the brands fit the 1st gen fbody fine. If you are interested in an OEM look with stamped tanks and the maximum cooling core design, check out our rebate offer in the Vendor sponsor section.
Fool around, Get hurt, Don't come cry'n to me.
Founder
Pypes Performance Exhaust
Cold Case Performance Radiators
Ccass is offline
post #6 of 13 (permalink) Old Jan 19th, 19, 04:09 PM
Sean
Iím using a be cool ďaluminatorĒ, fits great, and has worked great also. Very affordable and well built.
I recommend doing some research on the 4 core aluminum radiators. The whole point of using aluminum is to have larger tubes with more surface area (aluminum is stronger than brass so the tubes can be larger), which is why the high end aluminum ones use 2 large rows of tubes. The 3-4 row aluminum ones may work fine in many applications, but itís smoke and mirrors.
Ccass, HawkX66 and dhutton like this.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #7 of 13 (permalink) Old Jan 19th, 19, 06:51 PM Thread Starter
Tom Anderson
I went with a 3 core champion with the fan and shroud. Thanx for the input guys
post #8 of 13 (permalink) Old Jan 20th, 19, 03:12 AM
kevin
that is what I have. I think you will be happy
post #9 of 13 (permalink) Old Jan 20th, 19, 03:21 AM
kevin
if it works/cools, why is it smoke and mirrors? I have a friend using a 4 core on a blown 468 with 13-1 compression with no heating issues
post #10 of 13 (permalink) Old Jan 20th, 19, 04:19 PM
Sean
Originally Posted by flat tire View Post
[/COLOR]
Like I said, if your interested do some research with the best of the aluminum radiator manufacturers. Donít bother believing me, I wouldnít....
If a stock style copper brass 3 core works why waste your money on an inferior cooling material like aluminum if you are not going to utilize its benefits? If your 4 core or 3 core aluminum radiator works you could have saved money on a replacement copper brass and it would probably work better.
Smoke and mirrors.... or clever marketing. If 2 cores is good, 3 cores is better right? Regardless of tube size?
Sean
68rs406 is offline
post #11 of 13 (permalink) Old Jan 21st, 19, 06:36 AM
Eric
Cold Case offers 2 rows of 1.25" tubes and has polished OE style stamped tanks.
Direct fit. Even has the fan shroud clip on the bottom to attach the original shroud!
Offering $25 off radiators and $50 off fan modules right now as well!
ID:	224127   Click image for larger version
Follow Cold Case on Facebook and Instagram!
eric_cspan is offline
post #12 of 13 (permalink) Old Jan 21st, 19, 06:49 AM
keith
X-77 keith's Avatar
The Cold Case looks like a quality radiator. I like the way the hose pipes are all round and not squeezed down like some others. Champion is not bad either. I have used them in V-8 LS jeep swaps.
X-77 keith
X-77 keith is offline
post #13 of 13 (permalink) Old Mar 17th, 19, 10:04 AM
SoCal Tom - did you use your existing belt driven fan and shroud or do you have an electric fan? If so, can you give me the info? I'm faced with the same situation in a '68. Thanks
1968 Convertible, 355 ci 400 hp Blueprint sbc engine, 600 cfm Edelbrock, Performer intake, 4L60E, 10 bolt, 3:08
Troutslayer is offline
