68 Camaro Temperature Sending Unit - Console Guages - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 5th, 19, 02:55 PM Thread Starter
Lee
I have tested my temp gauge and it appears to be operating properly, but when I start the motor and warm it up, when the water in the radiator gets to 160 degrees the gauge only shows about 1/4. I think I need a different sending unit.
I watched a video on you tube of a guy trouble shooting a temperature gauge for the 68 Camaro with console gauges and he said the correct sending unit should be a TU12.
Could anyone verify that and I will go purchase that part number.
Lee
1968
Reggiecamaro1968 is offline
post #2 of 3 (permalink) Old Feb 6th, 19, 02:26 AM
Chick
68camaroz28's Avatar
Re: 68 Camaro Temperature Sending Unit - Console Guages
Lee
Lee, our 68ís used a sending unit with a push on pin type but not sure if that is a tu12 or not. Corvette houses like Paragon sell that 68 type so check that out. I show differences in design in my build thread if u search. But first note what u have both in sending unit and wiring attachment.
Chick
68, 69, & 2015 Z/28's
69 Nova's L34 Father/Son & L78 Surv purch-new
67, 68, & 2015 Z06 Corvettes
Our 68Z Restoration
68camaroz28 is offline
post #3 of 3 (permalink) Old Feb 6th, 19, 07:23 AM
Kevin
read post 6 in this thread. 1/4 on stock gauge is normal but can be changed
https://www.camaros.net/forums/19-el...ole-gauge.html
also check this post. It has a pic on one of the posts saying rough temp numbers for spots on a stock gauge and sending unit
https://www.camaros.net/forums/28-he...ld-needle.html
NH427 is online now
Searching for Red Color Rec on 68 Camaro Reggiecamaro1968 Body Shop 14 Oct 3rd, 18 02:54 AM
1969 Fuel tank sending unit emdoller Electrical & Wiring 14 Jul 27th, 18 06:42 AM
68 Console Fuel gauge sending unit wire routing. CM2RAS Electrical & Wiring 2 Jun 9th, 18 04:34 PM
