67 & 68 clutch fan used a spacer? - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 11th, 19, 04:03 PM Thread Starter
R66
Ron
So I put a 7 blade clutch fan on the 68RS about 20+ years ago. I replaced the water pump due to a very small amount of play in the bearings. I noticed the fan only sticks into the shroud by about 3/8". I believe it should be in about 1/2 of the depth of the fan blades.
I took a look in the Camaro Research Group site and found the clutch fan was a rare option for 67 & 68. The standard 4 blade fan used a 1-5/16" spacer.
I want to add a spacer for the clutch fan, but am concerned with the radial load on the short water pump bearings due to any slight out of balance of the clutch fan.
Does anyone know if a spacer was used on the 67 - 68 clutch fans on the short water pump?
Ron
R66 is offline
post #2 of 8 (permalink) Old Feb 12th, 19, 07:22 AM
Re: 67 & 68 clutch fan used a spacer?
..this site has spacers in various thickness...but description says for non fan clutch.
https://www.npdlink.com/search/produ...nt=7&year=1967
SoCal805 is offline
post #3 of 8 (permalink) Old Feb 12th, 19, 09:49 AM
Ron, This thread may help. I don't believe the factory used a spacer with a clutch fan.
https://www.camaros.net/forums/15-ta...ch-spacer.html
my 67' build thread:
allanjs is offline
post #4 of 8 (permalink) Old Feb 12th, 19, 02:21 PM
Russ
No, no spacer used on clutch fans. It's illustrated under UPC K02 of the AIM. I've no idea if the clutch assemblies were of differing heights/lengths and you have a wrong one, but in the 67 AIM they only list one plus an optional part number with no different applications indicated. And the parts books indicate that clutch is for 327/350/396s. The only thing remotely like a spacer would be the thin reinforcing piece that goes in between the pulley and the pump.
https://www.classicparts.com/1955-68...20group%20%231
Petes L48 is offline
post #5 of 8 (permalink) Old Feb 12th, 19, 03:43 PM Thread Starter
R66
Ron
No spacer is kind of what I came up with too.
The car is NOM and I used a Chrysler 7 blade fan. It has a 4 core radiator and doesn't overheat but gets up to 205 F or so in 90+ weather if I cruise in town. I just wondered if it would improve the cooling.
Thanks,
Ron
R66 is offline
post #6 of 8 (permalink) Old Feb 21st, 19, 07:43 AM
327 motor
FWIW I just switched from the stock 4 blade fixed fan to the 5 blade and fan clutch. I was concerned the fan with clutch would not be positioned like the fixed 4 blade with spacer.
The fan clutch measured exactly what the spacer was with my 4 blade 1 7/8" (from front edge of WP to where fan mounts) and the new 5 blade sits exactly within the fan shroud as my 4 blade did
Weird the way asymmetrical 5 blade is shaped (blades are not evenly spaced)
SoCal805 is offline
post #7 of 8 (permalink) Old Feb 21st, 19, 09:15 AM
Irregular spacing alters the harmonics to reduce noise.
Call for restoration and custom paint scheduling:
Sauron67MM is offline
post #8 of 8 (permalink) Old Feb 21st, 19, 09:32 AM
ok...I assume GM made size/weight balance adjustments for each blade so the 5 blade is "balanced"
By appearance, with engine running, fan spins evenly without any vibration in feel or visibly
I went from fixed to clutch fan on my 70 Torino 302 also years ago
In both cases for all the advantages of clutch fans but given here in sunny CA where our winters are like summers compared to many parts of the country....the car warms up faster with the clutch fan now that we are seeing 30 degree +/- weather here.
I had ordered a clutch fan from rockauto months ago. It did not fit. Went through the 20 ? "return" form for RA for a refund. They finally refunded the return. I just assumed my motor/WP for whatever reason did not accept a clutch fan. I then looked on Ecklers and the base was different from the RA ones. It was plug & play on install and net measurements of fan position was exactly the same as fixed blade.
Also the fan clutch from Ecklers is made in USA
SoCal805 is offline
Identifying this possible bumper from a 67 68 Camaro. Windymountain Body Shop 8 Dec 28th, 18 06:42 PM
68 Big block fan shroud SpitfireSS Restoration Corner 5 Jun 9th, 18 08:08 AM
67 68 RS Grille NOS value? Yellow69RSZ What's it worth? 2 Apr 9th, 18 12:53 PM
What fan and spacer? Kurtismcm Engine 3 Dec 26th, 17 05:30 AM
