Cooling - Page 6 - Team Camaro Tech
Heating & Cooling Heating, cooling and air conditioning Sponsored by:Cold-Case Aluminum Radiators
 23Likes
post #76 of 87 (permalink) Old Feb 27th, 19, 03:18 AM
Kevin
Re: Cooling
Originally Posted by 68rs406 View Post
Is the sensor rod completely isolated from the head casting then?
Iím not talking 30 degrees here, but on an iron head Iíve seen 10 degrees from head to intake. Iíve seen it, Iím not speculating.
If the OP has new everything and itís installed and running properly, which we really have to assume is the case because we are not there, there almost has to be something or a few somethings causing a higher than expected temp. Wouldnít you agree?
When obvious stuff isnít present donít you have to consider other avenues? Thatís what I do.
I would agree. In checking a water temp sensor/sender I had laying around, it looked to me like the probe is isolated by a sleeve from the outer "shell" that screws into the head (or intake manifold).
Perhaps the OP used an excessive amount of teflon tape on the threads prior to screwing in the sensor? The probe itself is a thermister, and the outer sleeve grounds itself to the engine when screwed in. I will only wrap the outer threads with one wrap of the teflon, allowing the inner threads to contact the engine metal for a good ground.
I do like the suggestion of using a heat detection gun to verify actual temps at the radiator, heads, and thermostat housing.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #77 of 87 (permalink) Old Feb 27th, 19, 10:55 AM Thread Starter
Lee
LeeC's Avatar
Re: Cooling
If to much teflon tape is used what would be the result? I don't believe it would stop at 205 all the time, not sure.
1969, X-11
383 5 speed, 373 rear
LeeC is offline
post #78 of 87 (permalink) Old Feb 27th, 19, 01:14 PM
DT
Donny
DT's Avatar
Lee, post a pic of your fan so the guys can see what fan you actually have.
DT is offline
post #79 of 87 (permalink) Old Feb 27th, 19, 04:01 PM
Sean
Re: Cooling
I suppose sensors vary but the ones Iíve used, or that I recall at least, are a compression fit between the base and the nut that holds it in. Itís subject to the temperature of the metal it mounts to, or thatís my assumption based on what Iíve seen with temperatures right there.
In a perfect world the water right there should be on the cooler side once the water was pumping through the block with an open system, it enters from the radiator right near there after all.
But I have physically seen higher readings with the sensor there, and surface temperatures with a heat gun.
My belief is the really close proximity to the exhaust ports heats the metal of the head in that area up. Especially iron. And when the coolant isnít flowing freely it will be worse.
Again, either location works fine, perfectly fine, but Iíve seen 10* difference as I recall which is not earth shattering. But we are talking about 205 now, 195 would be even less concerning. I still personally like to see temps closer to the stat rating though, but you are not overheating. Just watch it.
Thatís my experience at least. Results may vary, consult your physician.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #80 of 87 (permalink) Old Feb 28th, 19, 09:50 AM Thread Starter
Lee
LeeC's Avatar
Re: Cooling
I can't seem to upload a picture at this time. It says site can't be reached.
1969, X-11
LeeC is offline
post #81 of 87 (permalink) Old Feb 28th, 19, 10:20 AM
Darin
ilikeike's Avatar
Re: Cooling
Not sure if you know this, but you have to use Photbucket flickr or some other photo hosting site. Or be a paying member.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
post #82 of 87 (permalink) Old Feb 28th, 19, 10:29 AM Thread Starter
Lee
LeeC's Avatar
Re: Cooling
Don't have any of that
1969, X-11
LeeC is offline
post #83 of 87 (permalink) Old Feb 28th, 19, 12:02 PM
Re: Cooling
postimage is free and is what I use to put pics on this, and other, forums
SoCal805 is offline
post #84 of 87 (permalink) Old Feb 28th, 19, 01:06 PM
Kevin
Re: Cooling
I can't say for sure, but weak or poor grounds cause lots electrical issues. In this case? Perhaps not if it works to a certain temperature.
bucko is offline
post #85 of 87 (permalink) Old Feb 28th, 19, 02:28 PM Thread Starter
Lee
LeeC's Avatar
Re: Cooling
1969, X-11
LeeC is offline
post #86 of 87 (permalink) Old Feb 28th, 19, 02:49 PM
DT
Donny
DT's Avatar
Pic says Blocked?
DT is offline
post #87 of 87 (permalink) Old Mar 1st, 19, 04:34 AM
jeff
Re: Cooling
Don't see a problem. The factory thermostat was 195*. These engines were designed to run at 195+ degrees, 205 isn't bad.
jkuro is offline
Cooling system upgrade, 67, 350 Kiowa Heating & Cooling 14 Oct 8th, 18 03:15 AM
Looking for cooling solutions? Foxmlee Heating & Cooling 23 Aug 2nd, 18 01:43 PM
HELP COOLING QUICK. Overheating issues and not good Vintage A/C LYK2ROC Heating & Cooling 4 Jul 3rd, 18 06:34 PM
Parade Duty Cooling Question 1969z11 Heating & Cooling 7 Mar 12th, 18 08:08 PM
1989 Iroc-Z cooling fans 13 Crows Third Generation 9 Mar 3rd, 18 04:33 AM
