A/C hose crimp fitting orientation ??? - Team Camaro Tech
 3Likes
post #1 of 20 (permalink) Old Mar 8th, 19, 05:42 AM Thread Starter
Frank
I'm about to route my Vintage Air lines but don't have compressor yet. I have a pretty good idea of where and how the fittings will need to be oriented, and based on the natural curve of the A/C hose, I believe I can get them close to the right orientation ... How big of a deal is it if i'm off a little? Shouldn't be anything more than having to wrestle the hose some when connecting to the compressor, right?
'68 Camaro 454, 4sp
Just 1 More is offline
post #2 of 20 (permalink) Old Mar 8th, 19, 06:06 AM
Re: A/C hose crimp fitting orientation ???
That hose doesnít twist very easily. I wouldnít do it.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 20 (permalink) Old Mar 8th, 19, 06:09 AM
Vega$69's Avatar
X2 install the compressor 1st and make sure the fitting are clocked correctly before crimping.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 20 (permalink) Old Mar 8th, 19, 08:25 AM Thread Starter
Frank
Well crap.. That means i'll need to buy myself an A/C hose crimper for later use. Is there a good cheap one I should get?
'68 Camaro 454, 4sp
post #5 of 20 (permalink) Old Mar 8th, 19, 08:44 AM
Vega$69's Avatar
You can install the compressor and mock up the ac lines then take them to a shop and have the fittings crimped. Mark the clocking positions on the hoses and fittings.
Some crimpers on eBay for under $100. Donít know the quality of them.
I have a hydraulic one that cost about $800.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #6 of 20 (permalink) Old Mar 8th, 19, 08:57 AM Thread Starter
Frank
Can't do any of that since I have not purchased the compressor or pulley system yet
'68 Camaro 454, 4sp
post #7 of 20 (permalink) Old Mar 8th, 19, 09:21 AM
Sell them when you are done:
https://www.ebay.com/itm/VPA-424005-...IAAOSwwS5cFhBN
post #8 of 20 (permalink) Old Mar 8th, 19, 10:03 AM
Jon
I have this crimper. have used it to do 2 vehicles without any issues.
ordered the vintage air hose kits off ebay and made the hoses in just a few minutes.
worth the price for the convenience.
just my .2 for what its worth
saon is offline
post #9 of 20 (permalink) Old Mar 8th, 19, 10:12 AM
Another option is to use EZ clip hoses. But that will likely cost you as much as the crimper. I like the EZ clip even though I have a hydraulic crimper. Hoses are smaller diameter.
post #10 of 20 (permalink) Old Mar 8th, 19, 11:22 AM
Patrick
I would think that you could test fit the hoses and fittings. Paint mark the hose and fitting when the fitting is clocked correct position. (Use at least two paint marks.) Then bring the hoses and fittings to an automotive ac shop. They could crimp them for a nominal fee.
Liquid White Out will rub off of the hose and fittings after crimping.
Money can't buy you happiness but it can buy you car parts which is bout the same thang.
Patrick
tp_smith is offline
post #11 of 20 (permalink) Old Mar 8th, 19, 12:06 PM
Yes you can but he doesnít have the compressor for the test fitting so difficult to get the length and clocking correct. Those hoses donít twist well in my experience....
He wants to install one end and then crimp the other end when they are on the car.....
Just 1 More likes this.
post #12 of 20 (permalink) Old Mar 8th, 19, 12:33 PM
Patrick
You are right. I assumed from the previous post that Mr. Frank knew he needed the compressor mounted in place. It is best to screw the fittings into the compressor and the firewall, route the hoses, stick the hose in the fittings. Then paint mark the hoses and fittings.
I was offering a suggestion to save some money on a tool he might use one time.
Patrick
tp_smith is offline
post #13 of 20 (permalink) Old Mar 8th, 19, 02:39 PM Thread Starter
Frank
Yeah, That would be the right way to do it.. but, this is me we're talking about.. I rarely ever do things the right way
Shannon4570 likes this.
'68 Camaro 454, 4sp
post #14 of 20 (permalink) Old Mar 8th, 19, 05:03 PM
Vega$69's Avatar
I have a crimper and use only reduced barrier hose.
Smaller diameter outside but same diameter inside as full barrier.
And flexible than full barrier ac hose.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #15 of 20 (permalink) Old Mar 8th, 19, 05:08 PM
Patrick
Most of the time I have to redo my great ideas. I usually take one step forward and two steps back.
1. You need a swivel Freon hose joint. Let me know if you find one.
2. You could coil the Freon hose in the shape of a spring. That way you can clock the fitting in any direction. You have to admit. Your car would be different.
I will tell you right now, my two great ideas won't work.
Patrick
tp_smith is offline
A/C Belt Trouble shooting lvmy68 Heating & Cooling 2 Jul 24th, 18 04:03 PM
BB heater hose location on 69 Camaro Hgger69 Restoration Corner 5 Apr 6th, 18 06:14 AM
