Radiator recommendations 67 Camaro w/383 - Team Camaro Tech
 1Likes
  • 1 Post By Vega
post #1 of 9 (permalink) Old Mar 17th, 19, 09:40 AM Thread Starter
After extensive research I think I've narrowed down my cooling problem. I have a 21" non AC stock radiator in my Camaro. I also have a factory shroud installed that is for an AC radiator. The shroud doesn't fit right and previous installer had to do some trimming to get it to fit. There are gaps along the sides of the shroud where it should be touching the radiator. Gaps are smaller at the bottom of the radiator and get bigger (1/2") at top. In doing research I found a factory style 3 row radiator for manual transmission cars with AC (copper built). https://www.camarocentral.com/67_69_...PD_p/rad-4.htm . I am also interested in the Cold Case radiator but Cold Case doesn't offer a small block radiator with factory AC option. I intend to replace my radiator shroud and my radiator at the same time. I have Vintage air condensor mounted in front of radiator and small transmission cooler mounted off to the right corner in front of the condensor. Also my clutch fan only goes into the shroud about 1/4 of the way. The shroud I have now is 7 1/2" deep. I am trying to order the proper radiator and shroud and am not sure which are correct. Any guidance is greatly appreciated.
ID:	225697   Click image for larger version
1967 Camaro
383 stroker
Automatic
Duneit is offline
post #2 of 9 (permalink) Old Mar 17th, 19, 12:28 PM
Vega$69's Avatar
Re: Radiator recommendations 67 Camaro w/383
I have used many many Superior Radiators from DISSRAD on eBay on everything from BBC to blown LS motors. Always cool great in the crazy Vegas heat
kookykrispy likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 9 (permalink) Old Mar 17th, 19, 12:39 PM Thread Starter
I guess I should call them and ask them the same questions I've asked here? What shroud, how to get the clutch fan inside the shroud, and what radiator? I don't trust salesmen to sell me what I need. I trust fellow members who have experience actually installing the product.
Thanks anyway.
1967 Camaro
383 stroker
Automatic
Duneit is offline
post #4 of 9 (permalink) Old Mar 17th, 19, 02:46 PM
Chris Casperson
Send a message via AIM to Ccass
Based on this info, I'd get the CC BB MT radiator and make sure you order a BB fan shroud for proper fitment. This differs from my answer in the other topic because of your willingness to get a new shroud.
Fool around, Get hurt, Don't come cry'n to me.
Founder
Pypes Performance Exhaust
Cold Case Performance Radiators
Ccass is offline
post #5 of 9 (permalink) Old Mar 17th, 19, 02:47 PM Thread Starter
Where should I purchase the radiator? Summit?
Thanks again!
1967 Camaro
383 stroker
Automatic
Duneit is offline
post #6 of 9 (permalink) Old Mar 17th, 19, 02:55 PM
Chris Casperson
We have MAP pricing so most places you order will be the same price. Summit, Jeg's Ground Up, NPD, Classic Industries all stock Cold Case. I sent you a PM with options.
Founder
Ccass is offline
post #7 of 9 (permalink) Old Mar 17th, 19, 02:57 PM Thread Starter
Thank You!!!
1967 Camaro
383 stroker
Automatic
Duneit is offline
post #8 of 9 (permalink) Old Mar 18th, 19, 11:16 AM
OP
You have a 21" radiator but it sounds like you have a SB fan shroud for a 23" radiator which was used on 327 cars with AC...which was cut down to "somewhat" fit your 21" radiator
You have aftermarket aluminum radiator and fan shroud options noted by Vega$$. Or you can buy a 23" copper core 3 row from rockauto for example and then get the correct shroud that is not cut down
https://www.summitracing.com/parts/oer-3893814
a stock fan clutch and fan (5 blade asymmetrical) , for me, sits 1/2 way in/out of this set up
SoCal805 is offline
post #9 of 9 (permalink) Old Mar 18th, 19, 11:21 AM Thread Starter
I think I've figured out I have the BB radiator for a SB with AC. My cores are 21" but radiator overall is 26 1/2". I have a new radiator and shroud coming. Thank you!
1967 Camaro
383 stroker
Automatic
Duneit is offline
67 Camaro sub frame Briguy13 Brakes, Suspension & Steering 5 Feb 9th, 19 04:31 PM
Is a 67 Firebird rear seat the same as 67 Camaro deluxe 68resto Interiors 2 Nov 14th, 18 07:32 PM
Vintage Air in non OE AC 67 Camaro Bill Bergen Heating & Cooling 9 Sep 6th, 18 05:59 PM
