Temp Sensor Location - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 24th, 19, 11:16 AM Thread Starter
67, 327
Adding a temp gauge and keeping the stock "light" sensor on manifold.
Any concerns using the port on water pump vs intake manifold?
I could "T" the manifold but would rather not have that "plumbing" and just use the 1/8" NPT WP port for the gauge
SoCal805 is offline
post #2 of 3 (permalink) Old Mar 24th, 19, 11:29 AM
bob
Re: Temp Sensor Location
I would highly question the accuracy of a WT sensor in a water pump. The "cool" water from the radiator is going into the water pump, then into the engine.....so you won't really be reading what the engine temp is. There is a reason GM put the temp sensor in the intake. Is the idiot light that important that you don't want to remove it?
There is a good water flow schematic on this website: engine water pumps | Grumpys Performance Garage
bob15 is offline
post #3 of 3 (permalink) Old Mar 24th, 19, 11:42 AM Thread Starter
No the idiot light is not critical but I would prefer to keep it.
I suspected the manifold temp is more "real" water temp vs WP....
I have a 1/2" T fitting I can use so both are from manifold
Adding oil pressure gauge also and was doing a T for that one on back of motor so the dash cluster light is also preserved. That sensor location is tucked behind motor so the extra "plumbing" is not a eyesore.
I will see if it looks to busy for water and if so will bail on the dash light function...
SoCal805 is offline
Advice needed - Temp gauge AlamocitySS Heating & Cooling 4 Dec 2nd, 18 05:07 AM
Temp Gauge Wiring bobgonefishin Electrical & Wiring 2 Nov 8th, 18 11:40 AM
Weird Temp Gauge Readings BeefSupreme Engine 5 Mar 25th, 18 12:18 PM
Need to test water temp gauge and wiring larry williams Electrical & Wiring 3 Feb 16th, 18 04:46 PM
69 396 temp sensor part number scottcleaver Camaro Tech 5 Dec 29th, 17 05:15 AM
