Cold Blooded - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 28th, 19, 08:55 AM Thread Starter
Cold Blooded
Installed a AutoMeter temp gauge (sender in intake manifold) and now see what temp, according to gauge, motor runs. Dash light "works" but IDK what temp the motor was actually running at
I was able to get it up to about 140ish after a 10 min warm up and then a 10 min drive on Fwy.
Car runs fine. 180 T stat, 23" radiator, fan clutch, 5 blade, shroud
I suspect in the dog days of summer it will run hotter but seems fairly cold blooded now. Same thing with my neighbors 327 in his truck, about 140 for his also
SoCal805 is offline
post #2 of 10 (permalink) Old Mar 28th, 19, 12:06 PM
Vega$69's Avatar
Re: Cold Blooded
If you have a 180* stat the engine should operate at a minimum of 180*
So either your stat is not working correctly or the gauge is wrong. I would use an infrared sensor to determine which is not right.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 10 (permalink) Old Mar 28th, 19, 12:51 PM Thread Starter
Re: Cold Blooded
yeah stat could be opening to much....although it takes quite a while for upper hose to get warm so stat is definitely closed when engine is cold. I have a IR temp gun....exhaust manifold and T stat housing and radiator have all shown fairly cool temps compared to my other SBC although it is a 11:3 compression 383 motor. It runs 180 ish
Plugs are tan in color
SoCal805 is offline
post #4 of 10 (permalink) Old Mar 28th, 19, 09:42 PM
Darin
ilikeike's Avatar
Re: Cold Blooded
Like John said. If has a 180 T-stat it should run 180 minimum after a warm up.
Something is off or not reading correctly if it doesn't run 180.
Or your heater works so good you don't need a radiator.,lol.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #5 of 10 (permalink) Old Mar 29th, 19, 03:21 AM
keith
X-77 keith's Avatar
The thermostat might not be closing at all. I had a truck back in the day that I did not run a thermostat in. The temps were like you are describing.
X-77 keith
X-77 keith is offline
post #6 of 10 (permalink) Old Mar 29th, 19, 04:50 AM
Ed
Re: Cold Blooded
140 is too cold for the engine. You need to be at least above 160.
ZEN357 is offline
post #7 of 10 (permalink) Old Mar 29th, 19, 08:15 AM Thread Starter
Re: Cold Blooded
The temp sender for the gauge is in a "T" fitting that is in intake manifold so it is about 1" higher than just a single sender. I doubt this would have any affect on temp reading, at least not a 20 degree difference, but wanted to add that note.
The T stat may be bad, although it is only a few months old. Heater core (read entire heater box) was replaced by PO. Radiator is a 23" and looks to be in very good condition
Oil pressure does drop about 5 psi from cold start (25+ psi) to about 20+ at idle (650 rpm) when engine is warmed up which to me is normal as engine gets to "operating temp". Increases as RPM's increase.
I will run the car for a good drive and check various positions with IR gun today.....maybe the new Autometer gauge is off or the sender is off spec. Signal wire is a one piece new wire from gauge to sender
SoCal805 is offline
post #8 of 10 (permalink) Old Mar 29th, 19, 09:48 AM
Darin
ilikeike's Avatar
Re: Cold Blooded
I guess too cold is better than too hot anyway
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #9 of 10 (permalink) Old Mar 29th, 19, 11:48 AM Thread Starter
Re: Cold Blooded
Well after a long street ride the temp sits at 150 which corresponds to IR reading at sender & T stat. My guess is T stat opens to full to soon or is just stuck open. Temp does go 185 after car has been shut off after a drive which also corresponds to the IR gun at sender/T stat
Looks like gauge is right, now need to swap T stat
When driving at Fwy speeds temp gauge showed 140
SoCal805 is offline
post #10 of 10 (permalink) Old Mar 31st, 19, 12:37 PM Thread Starter
Re: Cold Blooded
UPDATE:
Swapped to a new 180 stat. Old one was only a few months old. It was the "fail open" type....which it did. Would explain why it took so long to warm up
After a drive the temp showed about 150 so I used IR gun to compare it to sensor. Sensor was 150. The manifold was 158 1" away (sensor is in brass T fitting). Heater hose fitting on manifold showed 158. Heater hose off of water pump shows 165.
I only have a intake manifold port for temp sensor, not one on the heads.
So depending on where temp measurement is taken it varies but on engine manifold itself directly at sensor fitting and manifold the operating temp is 158-165
I was stuck for a hr on Fwy today creeping along (read you could walk faster) and temp climbed to 210 after a hr of that kind of driving but not any hotter. Once I did get moving it quickly dropped down to 170 and stayed there
So cooling system seems to be working well
SoCal805 is offline
Cold Case Introduction eric_cspan Heating & Cooling 20 Oct 16th, 19 05:47 AM
Cold Case is Crusin' to a Location Near You! eric_cspan Heating & Cooling 12 Jul 18th, 19 01:22 PM
Cold Case Radiator review stamatisg1977 Heating & Cooling 8 Feb 7th, 19 03:57 PM
Cold Case factory rebate Ccass Heating & Cooling 0 Jan 18th, 19 09:00 AM
Cold misfire C7mark2014 Sixth Generation 2 Jun 8th, 18 04:43 PM
