Coolant Additive - Team Camaro Tech
 2Likes
  • 2 Post By Vega
post #1 of 7 (permalink) Old May 12th, 19, 10:57 AM Thread Starter
Aziz1969
Coolant Additive
Hi All,
I have 69 camaro with fresh built MKIV 427, aluminum radiator, aluminum intake, aluminum heads, and aluminum water pump. I am thinking to put "Summit Racing® Ice Water Coolant." Is it good staff? Should i add a bottle of "Lucas Super Coolant" or not? I am not worry about the antifreeze cuz i am in a place that the minimum temp in the winter is 36 degree. Lucas Super Coolant website mentioned that mix one bottle with 50/50 or 2 bottle with tap water, they do not recommend it with distilled water.
Recommendations
Aziz2010 is offline
post #2 of 7 (permalink) Old May 12th, 19, 11:35 AM
Vega$69's Avatar
Re: Coolant Additive
I’ve tried a couple of the water wetter and other additives and observed no difference in operating temps.
rp930 and wireboy355 like this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 7 (permalink) Old May 12th, 19, 12:01 PM
kevin
I have used the lucas and am a firm believer.
what have you got to loose by trying it?
flat tire is offline
post #4 of 7 (permalink) Old May 13th, 19, 05:56 AM
Bruce
Prestone Anti freeze works too.
The Camaro Guy is online now
post #5 of 7 (permalink) Old May 13th, 19, 02:56 PM
See guys at the track run water wetter, purple ice, and such.... anti-freeze is a no no due to track clean up if a spill happens. (but lots of street cars still do and isn't a problem)
68 Camaro~LSx ~all motor
post #6 of 7 (permalink) Old May 13th, 19, 03:36 PM
bob
I know a few people who add a small amount of dish soap to the cooling system in their oval track cars. It basically acts the same as water wetter, breaking the water tension.
bob15 is online now
post #7 of 7 (permalink) Old May 13th, 19, 04:43 PM
Darin
ilikeike's Avatar
Yep, does the same for herbicides also.
Old timers put use to put a little diesel in the spray tanks, the oil helped break tension of the spray on the weeds
I ran a bottle of the Red Line water wetter. Don’t know if it’s any better but my car runs cool.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
coolant additive for aluminum heads? Lance Heating & Cooling 1 Mar 7th, 08 09:43 AM
Aluminum Radiator - Pink Coolant? SR77 Heating & Cooling 7 Jan 9th, 08 01:39 PM
Whats the best radiator coolant additive to cool better? STM69 Heating & Cooling 7 Jun 17th, 06 06:36 PM
Hyper-lube as engine coolant additive mikestr Engine 13 Mar 1st, 02 09:17 AM
is 220 bad? jvolk81 Tech 2001 15 Oct 26th, 01 02:11 PM
