Hood insulation - Team Camaro Tech
 1Likes
  • 1 Post By Sauron67MM
post #1 of 13 (permalink) Old May 20th, 19, 04:14 AM Thread Starter
Hood insulation
Why would you do this? Back in the day i had to put a L88 hood on my car to gain carb clearance but it seemed to me back then that the biggest benefit i got from that hood was engine compartment venting. I have been puzzling a little on how to retain a stock appearing hood but to vent the compartment when i get shown an ad for a complete underhood insulation package. I am guessing im in the minority in this effort. Am I?
3d cad is online now
post #2 of 13 (permalink) Old May 20th, 19, 04:58 AM
Ed
Re: Hood insulation
Hodd insulation is used so the heat from the engine doesn't ruin the paint on the hood I would guess at least that's what I always assumed.
ZEN357 is offline
post #3 of 13 (permalink) Old May 20th, 19, 05:36 AM
Re: Hood insulation
Hood insulation was for sound deadening and part of the RPO Z87 package.
69-Pace likes this.
Call for restoration and custom paint scheduling:
Sauron67MM is offline
post #4 of 13 (permalink) Old May 20th, 19, 06:18 AM
Vega$69's Avatar
Re: Hood insulation
X2 for sound
With regards to under hood venting. There is so much air moving in the engine bay when the car is moving added venting is not needed.
Vega$69 is offline
post #5 of 13 (permalink) Old May 20th, 19, 09:09 AM Thread Starter
Re: Hood insulation
Not sure I agree with you about the air John. Back in the day after a build I had a heating issue on this car, not bad but a nuisance. When I dropped that glass hood on it it cleared up. My oil temp/pressure profile also changed at the same time which I promptly misinterpreted. The am radio lost any semblance of functionality too. Does hood insulation have a great impact on cab noise?
post #6 of 13 (permalink) Old May 20th, 19, 11:41 AM
keith
X-77 keith's Avatar
Glass hood would tick off the old radio's. Corvette's had a metal cover over the distributor bc of the glass.
X-77 keith
X-77 keith is online now
post #7 of 13 (permalink) Old May 20th, 19, 08:16 PM
Roger
rogerh's Avatar
Re: Hood insulation
Glass hood?
rogerh is offline
post #8 of 13 (permalink) Old May 21st, 19, 12:31 AM
Steven
stamatisg1977's Avatar
Glass hood?
Fiberglass
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #9 of 13 (permalink) Old May 21st, 19, 03:13 AM
keith
X-77 keith's Avatar
Yes fiberglass
X-77 keith
post #10 of 13 (permalink) Old May 21st, 19, 03:55 PM Thread Starter
Re: Hood insulation
Hopefully this time around the original hood is going back on. I wish i could find a glass SS hood just to shave weight. I still would like to vent it.
post #11 of 13 (permalink) Old May 21st, 19, 04:37 PM
Vega$69's Avatar
Re: Hood insulation
Go hoodless. Will save weight and give the ultimate engine bay venting. JK
Vega$69 is offline
post #12 of 13 (permalink) Old May 21st, 19, 05:40 PM
Re: Hood insulation
Hood vents just behind the core support have been shown to significantly reduce underhood temperatures.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #13 of 13 (permalink) Old May 21st, 19, 07:37 PM Thread Starter
Talking Re: Hood insulation
John, if i had a big block, a 6/71, and a ton of chrome iíd go for it but iím not that cool....
Removing hood insulation clips Grifter Restoration Corner 5 Feb 19th, 19 03:02 PM
Correct hood insulation for 68 RS VitaminC Restoration Corner 3 Mar 20th, 17 02:20 PM
cowl hood adjustment 68C Body Shop 16 Jan 30th, 14 07:08 AM
Hood insulation darrellv Restoration Corner 12 Jan 6th, 13 03:13 PM
Adjustment to fender? Winch Body Shop 4 Mar 10th, 02 01:46 PM
