Overheating - Team Camaro Tech
post #1 of 16 (permalink) Old May 28th, 19, 07:28 AM Thread Starter
Aziz1969
Overheating
Hi,
I have a 69 Camaro with M-IV 427, .030 over, edelbrock aluminum heads (#60499). It has new Becool aluminum radiator (#10168), stewart CCW water pump (#11105), March serpentine pulley set (#20517) with AC, 160 degree stat with 3 bypass holes (#emp-300). It has MKVIII fan; first speed turn on 140 degree and second speed turns on 185 degree. Radiator has Summit racing coolant (#sum-943000) with a bottle of wet wetter.
Have not turn the AC on yet. temperature scroll up to 230 when idling for 10 minutes then I shut the engine off. outside temperature is 100 degree.
NEED HELP
Aziz2010 is offline
post #2 of 16 (permalink) Old May 28th, 19, 07:50 AM
kevin
Re: Overheating
did this just start?
new engine/old engine
checked the plugs for a blown head gasket?
fan wired right way?
have a shroud?
flat tire is offline
post #3 of 16 (permalink) Old May 28th, 19, 08:37 AM
Ben
Re: Overheating
be sure shroud is covering as much of the radiator core as possible and directing all the air the fan is moving through the core. not enough ignition timing advance can cause hot condition as well .this may not be an issue limited to your cooling system.
bhodgdon400 is offline
post #4 of 16 (permalink) Old May 28th, 19, 10:09 AM Thread Starter
Aziz1969
Re: Overheating
It is new engine and the fan shroud is custom and it is covering 98% of the radiator core. fan working very good.
Aziz2010 is offline
post #5 of 16 (permalink) Old May 28th, 19, 10:56 AM
Re: Overheating
you sure the fans are not running backwards..
SoCal805 is offline
post #6 of 16 (permalink) Old May 28th, 19, 03:36 PM Thread Starter
Aziz1969
Re: Overheating
Fan is running in the right direction
Aziz2010 is offline
post #7 of 16 (permalink) Old May 28th, 19, 03:42 PM
Beth
Re: Overheating
What's the initial timing set at ?
Vacuum advance hooked up to manifold or ported vacuum ?
What type of cam and how much vacuum do you have at idle ?
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #8 of 16 (permalink) Old May 29th, 19, 05:27 AM
Eric
Re: Overheating
Air pocket in the radiator?
Follow Cold Case on Facebook and Instagram!
eric_cspan is offline
post #9 of 16 (permalink) Old May 30th, 19, 09:55 AM Thread Starter
Aziz1969
Re: Overheating
Timing is 8 initial and 32 total.
Aziz2010 is offline
post #10 of 16 (permalink) Old May 30th, 19, 09:56 AM Thread Starter
Aziz1969
Re: Overheating
It is a G-Straub custom HFT cam.
vacuum advance hooked to the ported vacuum
Aziz2010 is offline
post #11 of 16 (permalink) Old May 30th, 19, 10:00 AM
Darin
ilikeike's Avatar
I’m not sure if it will fix your overheat issue, but you could do better with your timing curve using manifold vacuum.
Google or search here a bit on timing advance using manifold vac.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #12 of 16 (permalink) Old May 30th, 19, 10:09 AM
Chris Casperson
Send a message via AIM to Ccass
Re: Overheating
230 in 10 minutes is likely one of the suggestions above. Even if you had no fans, the car should not get that hot in 10 minutes.
Fool around, Get hurt, Don't come cry'n to me.
Founder
Pypes Performance Exhaust
Cold Case Performance Radiators
Ccass is offline
post #13 of 16 (permalink) Old May 30th, 19, 10:42 AM
DjD
DjD's Avatar
Re: Overheating
As a test, raise your initial to 14 or 16 and let it idle. If it solves the high temp at idle you need to work on a recurve or working with vacuum advance so you have more initial without adding to the total.
...Dennis
DjD is offline
post #14 of 16 (permalink) Old May 30th, 19, 11:17 AM Thread Starter
Aziz1969
I talked with the cam guy and he told me to set the initial at 18 and total 35??
Aziz2010 is offline
post #15 of 16 (permalink) Old May 30th, 19, 11:18 AM Thread Starter
Aziz1969
18-35 at 2600 rpm
Aziz2010 is offline
