Any junkyard fan that will fit Champion CC337E Radiator ? - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 13th, 19, 10:25 AM Thread Starter
Probationer
Waid
Looking for electric fan for Champion CC337E Radiator. Is there any cheap junkyard option for twin fan or single fan that would fit this radiator?
The core is 17" x 20-3/4"
waid302 is offline
post #2 of 4 (permalink) Old Aug 13th, 19, 11:22 AM
kevin
Re: Any junkyard fan that will fit Champion CC337E Radiator ?
is there a reason not to use a belt driven fan?
flat tire is offline
post #3 of 4 (permalink) Old Aug 13th, 19, 04:13 PM
With a slight mod or three, Lincoln Mark Viii or Taurus fan. You will also need a controller (2-speed)
68 Camaro~LSx ~all motor
post #4 of 4 (permalink) Old Aug 13th, 19, 06:48 PM
Chris
130fe's Avatar
Found these dimensions on the web- https://forums.corral.net/forums/ele...amcharger.html
- Mark VIII dimensions are 18.5 x 22 x 6 and 18" blades, not including the tabs.
- Mark VIII w/ trimmed tabs and trimmed depth dimensions are 18.5 x 22 x 5.25 and 18" blades
- Taurus fan dimensions are 18.5 x 23 x 5 inches, and 17" blades
If you use these, make sure you use 70 amp relays, the hi speed fan on them will draw a lot of power.
You might be able to use any of these if you are able to do some trimming and come up with custom brackets for mounting. Beware of cheap aftermarket low CFM fans out there.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
