will a 69 bb camaro fan shroud fit on a 67 bb camaro w long water pump - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 25th, 19, 08:15 AM Thread Starter
SCOTT
Question will a 69 bb camaro fan shroud fit on a 67 bb camaro w long water pump
hi
I have 67 camaro with a 1970 396 long water pumped engine installed using a 7 blade 18" clutched fan, I need more room around the fan, it rubs sometimes.
will a 69 big block fan shroud work? I know the opening on the 69 shroud is larger, will i need any other mounts to install?
thxs for the help
scott
KAWSAM62 is offline
post #2 of 7 (permalink) Old Sep 25th, 19, 08:59 AM
Beth
Re: will a 69 bb camaro fan shroud fit on a 67 bb camaro w long water
Originally Posted by KAWSAM62 View Post
hi
thxs for the help
scott
Is the fan perfectly centered in the shroud ?
You can enlarge the mounting holes and center the shroud to the fan.
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #3 of 7 (permalink) Old Sep 25th, 19, 09:23 AM Thread Starter
SCOTT
hi it is perfectly centered.
I have maybe 3/16" clearence on both sides of the fan,
it rubs when cold sometimes and usually fine when hot,
I do have the long water pump so things are not in the correct place as GM intended,
I figured since 69 was a long water pump big block, gm fixed the fan shroud clearence issue
and I could just install a 69 shroud and gain xtra clearence.
NPD shows a 69BB will work on a 67-68BB shroud with the adding of a different top mount?
thx scott
KAWSAM62 is offline
post #4 of 7 (permalink) Old Sep 25th, 19, 11:03 AM
Beth
thx scott
A BBC engine is in the same position in all 67-69 Camaros.
Is your fan a 17 to 18" diameter ? If not, your fan is too big.
The opening is typically 19 to 19.5"
post #5 of 7 (permalink) Old Sep 25th, 19, 11:57 AM Thread Starter
SCOTT
hi
my fan is 18"
the hole is 18 1/2
on a 67/ 68 fan shroud
I think on a 69 it is 19 1/2
thx for the help
scott
KAWSAM62 is offline
post #6 of 7 (permalink) Old Sep 25th, 19, 05:39 PM
Jeff
I have a 68 BBC with long water pump and I used a 69 BBC shroud and top mounting bracket. You have to have BBC frame mounts.
Thanks,
Jeff
1968 Camaro
Chevy68 is offline
post #7 of 7 (permalink) Old Sep 26th, 19, 06:19 AM Thread Starter
SCOTT
Thumbs up Re: will a 69 bb camaro fan shroud fit on a 67 bb camaro w long water
hi I have the correct frame mounts!
thx
for the help!
scott
KAWSAM62 is offline
