GM 772 Cooling Fan on 68 - Team Camaro Tech
 1Likes
post #1 of 21 (permalink) Old Oct 25th, 19, 04:22 PM Thread Starter
Hello all,
Keep your cool I have read many times that folks have used a 69 (or later) GM 772 Style fan on a 67 or 68 BB with great success. Sooo, I decided to abandon my noisy electric fans and go for it. I ordered and attempted to install the fan with a new 2707 Hayden fan clutch. Fundamentally everything bolts up just fine, but the the tips of the fan hit the underside of the upper shroud support Has anyone experienced this? If so, what was the solution? The car came with a Be Cool radiator years ago when i got it, but since the upper shroud is attached to the rad support, this should have no affect.
Any suggestions are greatly appreciated.
Thanks,
Thanks,
Mr. Fixit
Mr. Fixit is offline
post #2 of 21 (permalink) Old Oct 26th, 19, 04:45 AM
Jeff
Re: GM 772 Cooling Fan on 68
Originally Posted by Mr. Fixit View Post
Hello all,
Thanks,
Steve,
I have the 772 fan on my 68 BBC without any issues.
Thanks,
Jeff
1968 Camaro
Chevy68 is offline
post #3 of 21 (permalink) Old Oct 26th, 19, 05:57 AM Thread Starter
Originally Posted by Chevy68 View Post
Steve,
Thanks for the confirmation Jeff, I will study the situation in order to see what needs to move in order to make it work. If you donít mind, could you please let me know if you have BB engine mounts, long water pump and what the clearance is between the tip of the fan and the upper rad mount?
Thanks again,
Thanks,
Mr. Fixit
post #4 of 21 (permalink) Old Oct 26th, 19, 12:20 PM
Jeff
Thanks again,
Steve,
It is sitting on BB frame mount and currently has a long water pump with a 69 BB shroud with about 1Ē clearance at the top and sides of the shroud. It originally had a short pump with the 68 shroud without issues.
Thanks,
Jeff
1968 Camaro
Chevy68 is offline
post #5 of 21 (permalink) Old Oct 26th, 19, 06:20 PM Thread Starter
Steve,
Interesting. I believe that I have the same setup as you have described, but as I had stated previously the tips of the fan blades hit the upper fan shroud. This is taking place without the shroud installed which will only make matters worse. I spent the time I had today working in the vintage air install and never got to the issue at hand. Thanks again for your input Jeff.
Thanks,
Mr. Fixit
post #6 of 21 (permalink) Old Oct 27th, 19, 01:07 AM
Brett
I wonder if it could be your tranny mount? If your cross-member does not have the correct spacer/mount, it could cause your engine to sit low in the back, but high in the front. It would seem to me like a small amount on the tranny would have a larger effect on the front. Also, do you have a BBC shroud?
Brett....
Rockets Up In 2020!
Brettallen59 is offline
post #7 of 21 (permalink) Old Oct 27th, 19, 02:50 AM Thread Starter
Brett....
Brett,
The tranny mount spacer/shim is a great idea and makes perfect sense. The tranny is a TKO 600 with a BBC cross member that I installed new with the tranny some time ago. I think that I do recall having to play around with the level at the tail of the tranny in order to get proper drive shaft angle as a result of a full Hotchkis suspension which included lowering ride height.
Currently there is no shroud since I am just trying to dry fit a new fan and fan clutch assembly after removing an electric fan setup that was marginal to begin with. As mentioned, the tips of the fan blades hit the underside of the top shroud bracket with no shroud yet installed. I will get the car on the lift to check things out and get back soon. Thanks for the idea.
Thanks,
Mr. Fixit
post #8 of 21 (permalink) Old Oct 27th, 19, 04:51 AM
jeff
Check your pinion angle after you shim the transmission.
jkuro is offline
post #9 of 21 (permalink) Old Oct 27th, 19, 07:08 AM Thread Starter
Brett,
Follow up to the effort. I had in fact previously raised the rear mount .150 which was done in order to get alignment of the pinion angle. I just removed those shims and doubled the thickness to .300 and there was no virtually affect at the fan. I am wondering if I would need to loosen everything including the header collectors in order to get real results. Attached are a couple of pics of the fan issue.
Name:	Camaro Cooling Fan2.jpg
ID:	230089   Click image for larger version
Name:	Camaro Cooling Fan.jpg
Thanks,
Mr. Fixit
post #10 of 21 (permalink) Old Oct 27th, 19, 07:31 AM
Brett
Ah Ha! Steve, I found your problem. The shroud mount you have is a small block mount (either that, or this is a 69 BBC mount & shroud). Look at my pics below. I am using a BBC mount and shroud. The mount is much shorter and the shroud goes higher at the top, so that is how the fan clears. My fan is going the same height as yours.
Brett......
Rockets Up In 2020!
post #11 of 21 (permalink) Old Oct 27th, 19, 09:05 AM Thread Starter
Brett......
Brett,
That's awesome, thanks for the pics. The mount was already there and the PO used it to mount the top of the electric fans. It didn't occur to me that it may not be a BBC mount. I will look online to see the various years/stiles and go from there.
Thanks,
Thanks,
Mr. Fixit
post #12 of 21 (permalink) Old Oct 27th, 19, 12:14 PM
Jeff
That is the correct mount for a 68 BB, 69 used the short mount.
flat tire likes this.
Thanks,
Jeff
1968 Camaro
Chevy68 is offline
post #13 of 21 (permalink) Old Oct 27th, 19, 01:28 PM
Brett
I was afraid of that. Well if it would work for him to get the 69 shorty, wouldn't that be okay?
Brett......
Rockets Up In 2020!
post #14 of 21 (permalink) Old Oct 27th, 19, 02:34 PM Thread Starter
I looked it up and see that you are correct. Since I am not concerned with correctness, I think I could use the short bracket. I will likely fabricate a polished aluminum shroud anyway since I suspect that a factory one wonít fit properly.
Thank you,
Thanks,
Mr. Fixit
post #15 of 21 (permalink) Old Oct 27th, 19, 02:38 PM Thread Starter
Brett......
Thatís what I think I will do. Just hoping that there wonít be a hood clearance issue with the upward protruding radius of the shroud intersecting the underside of the hood. More to come. Thanks again for your help Brett.
Thanks,
Mr. Fixit
