Removing A/C hoses when pulling engine, whats the best place? - Team Camaro Tech
 5Likes
post #1 of 16 (permalink) Old Dec 26th, 19, 04:14 PM Thread Starter
Tim
Hi
I'm pulling my engine, and need to disconnect the A/C lines from the compressor and don't really want to disturb the "block" in the back of the compressor, unless I need to.
the A/C lines have these worm type clamps, if I undo the clamps will the hoses pull off? or is there more to the A/C hoses/lines that meet the eye? are they solid aluminum tubes with rubber coatings or true hoses?
appreciate it I don't want to destroy them
1967 RS/SS Coupe, Factory A/C, 2nd owner, original paint -Taho Turquoise 3 Spd on the floor, bench seat, fold down rear seat
1967 RS Convertible Factory A/C, PS, PB PG 327
Niblet is offline
post #2 of 16 (permalink) Old Dec 26th, 19, 05:07 PM
Re: Removing A/C hoses when pulling engine, whats the best place?
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 16 (permalink) Old Dec 26th, 19, 05:14 PM
If you score the toothed tubes like an animal as many do when cutting the hoses off, you could end up with a leak. Now you have to send parts out to have new ends installed.
Niblet likes this.
Call for restoration and custom paint scheduling:
Sauron67MM is online now
post #4 of 16 (permalink) Old Dec 26th, 19, 05:42 PM
post #5 of 16 (permalink) Old Dec 26th, 19, 08:02 PM
Dale
The hoses will not pull off the fitting even with the clamp removed.
Niblet likes this.
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline
post #6 of 16 (permalink) Old Dec 26th, 19, 09:06 PM Thread Starter
Tim
I believe you are correct, after I gave it a good tug. and the car moved,,I realized this wasn't correct, so I removed the Block at the compressor and all went well
I would have had to cut those hose off like an APE,,I did however bust the hell out of my AC "shroud" or whatever its called or it was busted before
even with a SBC there isn't much clearance between he A/C "box" and the exhaust manifold. I should have come forward more. but I got a cheap *** engine hoist
and that that dam "nub" on the PG held me up on the crossmember,,it was a **** show but I got the engine out
anyone have a 67 A/C box in great shape they want to sell?
Niblet is offline
post #7 of 16 (permalink) Old Dec 27th, 19, 05:16 AM
So you saved your 50 year old brittle hoses and you busted your evaporator suitcase.....
Iíve got a couple of evaporator suitcases.
post #8 of 16 (permalink) Old Dec 27th, 19, 07:19 AM Thread Starter
Tim
I'm not so sure those were the original hoses, they seem serviceable to me so I left them alone. This car never will be "original" so originality is not a factor here
How much do you want for your evaporator suitcases, ( I would be interested in a couple, as both of my cars have factory A/c)
if they are in good shape.
Who makes a decent quality replacement hose if I decide to go that route?
Thanks again
Niblet is offline
post #9 of 16 (permalink) Old Dec 27th, 19, 09:01 AM
Thanks again
Let me dig them out and send you a couple of pics. PM me your email address.
post #10 of 16 (permalink) Old Dec 27th, 19, 09:17 AM Thread Starter
Tim
Done,,PM sent
Niblet is offline
post #11 of 16 (permalink) Old Dec 27th, 19, 10:13 AM
Jeff
Why not just detach the A/C compressor from the engine?
It's only a few bracket screws.
Pull the engine - leave the A/C alone. that's what I always do.
Pacecarjeff is offline
post #12 of 16 (permalink) Old Dec 27th, 19, 10:15 AM Thread Starter
Tim
I would have gone that route if the system was intact, I gotta gain access and replace the heater core, dig into the dash, figure out why the fan doesn't blow,
etc etc and so forth, so in other words I'm going to end up with a new factory A/C system by the time its all said and done
Niblet is offline
post #13 of 16 (permalink) Old Jan 1st, 20, 10:35 AM
Russ
I believe those original R-12 era/type hoses are hard to find NOS or even generic, and probably would be "petrified" after 50 years if you could find them. From what I've heard, the newer type R134 hoses that the usual suppliers sell, have a firmer smoother lining, and are difficult to get a good seat and seal on the original style aluminum barbed fittings and higher pressure lines, especially when using the screw clamps. If factory correct is not needed, you may want to look into having something fabricated.
Petes L48 is offline
post #14 of 16 (permalink) Old Jan 26th, 20, 07:44 PM Thread Starter
Tim
Anyone else have an evaporator suitcase for a 67 sbc?
Niblet is offline
post #15 of 16 (permalink) Old Jan 27th, 20, 01:12 AM
Brett
Tim, There are a few on eBay. Figured you checked but in case you didn't here; Camaro Evaporator Case
Plus there are some Repop's on eBay HERE
HERE
HERE
HERE
...and HERE
Don't know if this is what you need, but maybe you can just replace the part that is broken.
Brett....
Rockets Up In 2020!
Brettallen59 is offline
