vintage air ac with a muncie 4 speed any issues? - Team Camaro Tech
 1Likes
  • 1 Post By Vega
post #1 of 4 (permalink) Old Feb 16th, 20, 04:09 AM Thread Starter
donnie
im thinking about running a vintage air ac system in my 67 with a Muncie 4 speed wide ratio and a 355 posi rear end.
I was told that its a bad idea due to the Muncie 4 speed with the 355 gears will wind the ac compressor too high for too long burning it up? didn't make since to me is why I asked here ANY THOUGHTS? I can go down to 308 rear gears if needed, ny car was a orig ac car and I want the system here in texas
dads67z is offline
post #2 of 4 (permalink) Old Feb 16th, 20, 04:43 AM
Vega$69's Avatar
Re: vintage air ac with a muncie 4 speed any issues?
The Muncie has 1:1 final drive ratio. Same as any other non OD tranny. No issues with AC compressor.
Just 1 More likes this.
Vega$69 is offline
post #3 of 4 (permalink) Old Feb 16th, 20, 04:58 AM Thread Starter
donnie
I was hoping you would answer since I saw where you install the systems, ill take your advice on rear gears also thanks
dads67z is offline
post #4 of 4 (permalink) Old Mar 21st, 20, 06:27 PM
Probationer
I just checked for availability of Sta-lube GL-4 85-90 gear lube. Only the 'corporate' NAPA stores have it in stock. About $9/quart. Buy 2 for a total refill.
maxsava987 is offline
