Hot Big Block - Team Camaro Tech
 1Likes
post #1 of 24 (permalink) Old Mar 12th, 20, 04:52 PM Thread Starter
Milt
Milt's 68 SS/RS 396's Avatar
Hot Big Block
My car is running great with the new EFI system but I continue to have a problem with it getting hot at idle. Took it out last weekend. It was about 70 degrees. While driving it was running at about 180 degrees. I stopped at the Jack in the box for some bacon cheddar potato wedges and while waiting it went up to 204. By the time I got home it had went down to 194. I have an Entropy aluminum radiator with a stock shroud and a 7 blade clutch fan itís about 2 inches from the radiator. I was thinking about getting a bigger spacer to get the fan closer. If that doesnít work, I might add an electric push fan. Any advice and or ideas would be appreciated.
Go big, or stay Home!
Milt's 68 SS/RS 396 is offline
post #2 of 24 (permalink) Old Mar 12th, 20, 05:13 PM
Re: Hot Big Block
Did it run hot before EFI?
What's the timing set at idle?
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #3 of 24 (permalink) Old Mar 12th, 20, 05:13 PM
Rick
Re: Hot Big Block
Is it a HD clutch fan? It looks about right for depth. Thermostat? And where is the temp sensor mounted?
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #4 of 24 (permalink) Old Mar 12th, 20, 05:15 PM
scblucam's Avatar
Re: Hot Big Block
From the picture it looks like the fan and shroud do not match. I mean the fan looks like it is a lot smaller than the shroud. I don't think you want it any closer to the radiator. That said I really don't think 204* is a big deal. I don't know about big blocks but my 302 doesn't like to run below 200*.
68 302 M20 - 85 IROC Z
scblucam is offline
post #5 of 24 (permalink) Old Mar 12th, 20, 05:29 PM Thread Starter
Milt
Re: Hot Big Block
Temperature wise, it ran the same before the EFI. Timing at idle is set at 15 degrees btdc. Sensor is mounted on the intake.
post #6 of 24 (permalink) Old Mar 12th, 20, 05:54 PM
Brett
Re: Hot Big Block
My 396 does not have any temperature issues with roughly the same fan set up. The difference is the radiator. I looked up Entropy and they show their two row radiators are 1" tubes. Mine is a Griffin and it has 2 rows, but I have 1.25" tubes. Could be just enough to make your environment. Since my 1.25" tubes make the radiator thicker, it moves the radiator closer to the fan without adjusting your fan location. My clutch is 1/4-1/2" from the radiator-pretty close.
P.S; Milt! how is your EFI working? I am installing EFI on mine now. I am excited.
Brett.....
Rockets Up In 2020!
Brettallen59 is online now
post #7 of 24 (permalink) Old Mar 12th, 20, 06:07 PM
bob
Re: Hot Big Block
How old is the clutch? Might be worth replacing or rebuilding. It might not be fully locking up and it runs cooler driving because you are forcing air through the radiator.
bob15 is offline
post #8 of 24 (permalink) Old Mar 12th, 20, 06:24 PM Thread Starter
Milt
Re: Hot Big Block
Brett.....
My fan is about 2 inches from the radiator. Perhaps a thicker spacer will do the trick.
EFI is working great, very responsive, but it was a hassle to get it all dialed in. I have a long thread detailing the whole process.
post #9 of 24 (permalink) Old Mar 12th, 20, 06:25 PM Thread Starter
Milt
Re: Hot Big Block
Clutch is relative new, very low miles on it.
post #10 of 24 (permalink) Old Mar 12th, 20, 07:29 PM
Brett
Re: Hot Big Block
Yes, that's why I asked. I followed the entire journey and really was hoping you would eventually like the EFI conversion. Was a real test for you tho.
Brett....
Rockets Up In 2020!
post #11 of 24 (permalink) Old Mar 13th, 20, 04:27 AM
jeff
Re: Hot Big Block
Car is not running Hot. They came with a 195* thermostat from the factory.
jkuro is offline
post #12 of 24 (permalink) Old Mar 13th, 20, 04:46 AM
Re: Hot Big Block
Depends on what he has for a thermostat to say it's not running hot. If he's running a 165, then it's running hot. If he's running a 195 then I might agree with you.
With an aluminum radiator, my temp never varies once it gets up to operating temp. I could be sitting for a 1/2 hour in the summer and it stays where it should. I doubt it has to do with getting the fan closer to the radiator.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #13 of 24 (permalink) Old Mar 13th, 20, 04:51 AM
bob
Re: Hot Big Block
Was there anything wrong with the old clutch? Was the engine temp the same and did it act the same?
What did you replace the clutch with? A Derale or a Hayden?
Was the old clutch the same distance from the radiator as what you have now?
bob15 is offline
post #14 of 24 (permalink) Old Mar 13th, 20, 11:17 AM
Re: Hot Big Block
Fan should be half in/out of the shroud. Distance from radiator has no effect. Some cars have very deep shrouds due to car construction and they have no cooling issues. Idle cooling temp will be lower if vacuum advance is hooked to full manifold vacuum and not ported.
Call for restoration and custom paint scheduling:
Sauron67MM is offline
post #15 of 24 (permalink) Old Mar 13th, 20, 01:55 PM
Chris Casperson
Send a message via AIM to Ccass
Re: Hot Big Block
you have at least an airflow problem.
1. shroud is not a good match to that radiator
2. fan looks a little small for that opening
3. Clutch could be inadequate
4. Entropy radiator is dual 1" tubes. Many times a big block wants more volume to keep temps down. A bigger radiator will definitely help.
5. EFI systems seem to breed hot running vehicles. I honestly can't say why but it's amazing how often I hear this issue.
Fool around, Get hurt, Don't come cry'n to me.
Founder
Pypes Performance Exhaust
Cold Case Performance Radiators
Ccass is offline
