Cutting my 4 spd tunnel hole - Team Camaro Tech
post #1 of 35 (permalink) Old May 13th, 15, 09:50 AM Thread Starter
I'm getting ready to cut my 4 speed hole in my new floor pan. I have a set of oxy/acetylene torches, but I think my head/tip might be too large. What size should I use to recreate the original look? I attached a couple of pics of my original tunnel. I was planning on drilling the four trim screw holes first and then measuring out the hole and laying down tape to follow. Any suggestions so I can get this right the first time would be [appreciated].
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #2 of 35 (permalink) Old May 13th, 15, 10:34 AM
kevin
Re: Cutting my 4 spd tunnel hole
1/8" 000, 1/4" 00 ,3/8" 0 ,1/2" 0
3/4" 1
1" 2
2" 3 12" 8** 45/55 7/25 10/15 3/5 .41
flat tire is offline
post #3 of 35 (permalink) Old May 14th, 15, 05:22 AM Thread Starter
Thanks for the post Kevin. Which one of those tips would make the cut look like the original did? I know enough about oxy/acetylene torches to heat up and cut metal. That's about the extent of my knowledge for them... Mine are the full size set. Not the baby bottles.
Is everyone just cutting them with a sawzall or jigsaw?
Semper Fi!
HawkX66 is offline
post #4 of 35 (permalink) Old May 14th, 15, 05:26 AM
DT
Donny
DT's Avatar
This may help as well: http://www.camaros.org/forum/index.php?topic=8472.0
DT is offline
post #5 of 35 (permalink) Old May 14th, 15, 05:29 AM
Gary
69Z28-RS's Avatar
Is the big block engine laterally displaced slightly from the small block?? Does that affect where the transmission/shifter is positioned? The previous reference was for a small block car (Z28)...
Gary
69Z28-RS
Corvettes (5), Nomads (2), El Camino, etc
69Z28-RS is offline
post #6 of 35 (permalink) Old May 14th, 15, 05:33 AM Thread Starter
Originally Posted by DT View Post
Thanks. I'll have to check that one out at home tonight. CRG started getting blocked a few months ago. Lame...
Yesuh. I'm just looking for the cutting technique though, so I'm not sweating the location. I have that locked on.
Semper Fi!
HawkX66 is offline
post #7 of 35 (permalink) Old May 14th, 15, 05:36 AM
DT
Donny
DT's Avatar
No. Big blocks use different shifter mounting brackets than Small Blocks. The 4 speed hole is in the same location for both engines.
DT is offline
post #8 of 35 (permalink) Old May 14th, 15, 05:38 AM Thread Starter
Oh ya... Thanks Donny. Forgot that the hole didn't move. Too quick a draw on the keyboard.
Semper Fi!
HawkX66 is offline
post #9 of 35 (permalink) Old May 14th, 15, 05:38 AM
DT
Donny
DT's Avatar
Here is what the torch cut looks like:
http://www.ebay.com/itm/1969-Camaro-...45e32c&vxp=mtr
DT is offline
post #10 of 35 (permalink) Old May 14th, 15, 05:43 AM Thread Starter
Dang blocked websites... Thanks again. I'll check it out tonight. I have my original tunnel to compare it though, so I know what it's supposed to look like. I posted a pic of it in my first post. I'm just trying to get the cutting head info and any other tips so when I make the cut it looks right.
Semper Fi!
HawkX66 is offline
post #11 of 35 (permalink) Old May 14th, 15, 05:43 AM
DT
Donny
DT's Avatar
This link has very specific hole location measurements. Highly recommend you review it.
DT is offline
post #12 of 35 (permalink) Old May 14th, 15, 05:46 AM Thread Starter
That I will. I appreciate the info.
Semper Fi!
HawkX66 is offline
post #13 of 35 (permalink) Old May 14th, 15, 05:47 AM
DT
Donny
DT's Avatar
The EBay link above shows a 4 speed tunnel replacement "hump" with the torch cut out by Camaro Specialties. Remember a torch was used so not all of the cut-outs are going to look exactly the same.
DT is offline
post #14 of 35 (permalink) Old May 14th, 15, 05:52 AM Thread Starter
I'm sure there's going to be some variation, but as long as the cut edge looks similar, doesn't look hacked, it's within the 4 trim screw holes and the shifter fits correctly, I'll be good with it.
I'm not going to include the screw up that it looks like they made on mine. If you look at the first picture, there's a cut out all the way over to the passenger side trim screw area. Must have been a rough Monday morning...
Semper Fi!
HawkX66 is offline
post #15 of 35 (permalink) Old May 14th, 15, 06:27 AM
DT
Donny
DT's Avatar
Are you cutting that out all together ?? That EBay link is the tunnel repair section with the torch cut-out already.
EDIT, I just read you have a new floor pan.
DT is offline
