Big block power steering - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 20th, 19, 12:35 PM Thread Starter
Probationer
New to the site need help...ive purchased a 69 w manual steering an big block.if somebody could help me with which steering box to use that will not interfere with headers....i talkd to rep at cpp an he stated that his box would not work..thnx
Jimmyhustle6869$ is offline
post #2 of 4 (permalink) Old Feb 21st, 19, 09:28 AM
Matt
Re: Big block power steering
I have a stock fast ratio power steering box in my 69 with hooker headers #2457. Its close but it clears.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #3 of 4 (permalink) Old Feb 22nd, 19, 03:31 AM
I'm also using the factory close ratio box with a BB, but I'm running manifolds. Be advised that if your car doesn't have the right frame BB stands for the motor mounts, your engine will be centered in the engine bay. GM offset the factory BB engine in the Camaro and Nova toward the passenger side 3/4" to gain clearance around the steering box. That will help immensely in getting clearance for headers. The factory BB cars also required a different crossmember. Notice the hump in the fan shroud and the offset between the air cleaner and the rib on the cowl panel.
buenymayor is offline
post #4 of 4 (permalink) Old Feb 22nd, 19, 04:45 AM
Bruce
I have an 89 IROC steering box from O'Reilys for $125. You will need to change the fittings on the box, got mine from Lee manufacturing. I have a 69 BB with Dynomax headers. . . .1/8" clearance. Not been a problem for 10 years. The IROC box is great and looks the same as the original.
The Camaro Guy is offline
Power Steering Fluid TJ's Destinity Brakes, Suspension & Steering 8 Aug 18th, 18 04:13 PM
Power steering box adapters zboss86 Brakes, Suspension & Steering 7 Jul 31st, 18 08:01 AM
Power Steering Belt Change ghamnik Camaro Tech 0 Jul 30th, 18 10:26 AM
Power steering upgrade RDW Brakes, Suspension & Steering 13 Jun 17th, 18 11:08 PM
Are jets my next step? 4Speed67CamaroRS Engine 19 Apr 10th, 18 09:37 AM
