Top soft parts assembly order - Team Camaro Tech
Convertibles Convertible Q&A's
 1Likes
  • 1 Post By KevinW
post #1 of 5 (permalink) Old Mar 18th, 19, 08:42 AM Thread Starter
Duke
I'm finally getting to the folding top on a '69 convertible this year. I'll start with the motor & cylinder work, but after that I'd like some opinions on the best order to approach installing the "soft" parts. I assume the convertible top weatherstripping needs to be installed before the final frame adjustment, in order to get the window adjusted correctly during the process. Is there any part of the top weatherstripping that can't be installed until after the top fabric is in place? I'm not in a financial position that would allow me to purchase the top and pay somebody to install it at the moment, but I'd like to get moving on the rest of the top assembly and adjustments.
1969 RS Convert getting closer to the road every day!
DElsner is offline
post #2 of 5 (permalink) Old Mar 25th, 19, 10:33 AM Thread Starter
Duke
Re: Top soft parts assembly order
Anybody out there?
DElsner is offline
post #3 of 5 (permalink) Old Mar 25th, 19, 12:22 PM
Patrick
1. Check the frame to see if any bushings are worn.
2. Check the header bow for rust.
3. Paint the frame.
4. Fold and unfold the frame by hand to see if it moves smoothly.
5. Add tack strips to the bows.
6. Check the windshield header clamps to see if the latch correctly.
7. Add the weather strip.
8. Replace the tensioner cables if needed.
9. Adjust the frame to make sure in closes properly.
10. Replace the top.
Patrick
tp_smith is offline
post #4 of 5 (permalink) Old Mar 26th, 19, 04:29 AM
Kevin
KevinW's Avatar
Duke, all the weather strip is installed after the top is glued to the frame. But the weatherstrip is just screwed to the frame. I would recommend installing them while you are adjusting the frame, then take them off for the canvas install, then back on again
dhutton likes this.
Kevin
KevinW is offline
post #5 of 5 (permalink) Old Mar 27th, 19, 06:42 AM Thread Starter
Duke
Thanks, now I know how to proceed.
DElsner is offline
1969 firebird convertible with photos tp_smith Build Projects 300 Apr 10th, 19 08:48 AM
RockAuto.com Discount Code for Parts & More - Expires July 1, 2019 RockAuto RockAuto 2 Jan 4th, 19 06:34 PM
best parts Larger Dave Camaro Tech 25 Dec 3rd, 18 03:24 PM
soft top frame installation Chris1969 Convertibles 2 May 18th, 18 02:10 PM
RockAuto.com - Order Parts and Pay 24 Hours a Day…with Cash! RockAuto RockAuto 0 Mar 21st, 18 08:20 AM
