Headers - LS3 Swap - Team Camaro Tech
Exhaust and Headers Discussion related to Exhaust systems and headers.
Sponsored by: Pypes Performance Exhaust
 2Likes
  • 1 Post By Vega
  • 1 Post By 130fe
post #1 of 12 (permalink) Old Mar 20th, 19, 10:20 AM Thread Starter
Bobby
Headers - LS3 Swap
I have a 1968 Camaro that currently has original Straight Six in her, making plans to put in a LS3 and looking for what headers will fit with least amount of interference issues?
My YouTube LS3 Engine Swap Page
My LS3 Engine Swap Thread
Sixty8Camaro is online now
post #2 of 12 (permalink) Old Mar 20th, 19, 04:38 PM
Re: Headers - LS3 Swap
https://www.jegs.com/i/Dynatech/329/...ntent=Dynatech
But I have a manual steering box also...
68 Camaro~LSx ~all motor
post #3 of 12 (permalink) Old Mar 20th, 19, 04:55 PM Thread Starter
Bobby
[QUOTE=But I have a manual steering box also...[/QUOTE]
I guess that suggest that with my power stearing unit I may hav issues.
post #4 of 12 (permalink) Old Mar 20th, 19, 04:57 PM
Vega$69's Avatar
Many factors involved. Are you putting engine in stock position or moving it forwards or back? What crossmember? Auto or manual tranny? Mechanical or hydraulic clutch?
DT likes this.
66 Chevelle Protour LS3/525SOLD at Mecum 2018
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 12 (permalink) Old Mar 20th, 19, 05:41 PM Thread Starter
Bobby
It will be an automatic, perhaps a 4L65E?
Should I assume that the following will put the engine in the stock location?
HOOKER BLACKHEART ENGINE MOUNT BRACKETS #12618HKR
HOOKER BLACKHEART HEAVY DUTY CLAMSHELL ENGINE MOUNTS #71221004HKR
HOOKER BLACKHEART TRANSMISSION CROSSMEMBER #12625HKR
post #6 of 12 (permalink) Old Mar 20th, 19, 06:20 PM
Only that I can't verify the fit since I don't have.
MuscleMaxx Header Systems are designed to directly bolt-on without modifications. Constructed with 3/8" thick CNC laser cut and machine surfaced flanges, they provide a long lasting leak free seal. For use with straight or angle plug heads, multiple steering boxes, and automatic or manual transmissions. These headers provide excellent ground clearance when used with the factory engine mounts and stands. Available with Black painted finish or ceramic coated (inside and out) finish and with all hardware included. Ball and socket type collector reducer cones are included (except where noted) to connect the headers to a Dynatech MuscleMaxx Dual Exhaust System or other exhaust.
post #7 of 12 (permalink) Old Mar 20th, 19, 06:43 PM
Chris
130fe's Avatar
Holley all the way. Their stuff works awesome.
DT likes this.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #8 of 12 (permalink) Old Mar 22nd, 19, 08:54 AM
Kip
Yup... Holley LS swap parts fit perfectly. I didnt even have to "massage" the headers. No floorpan mods either with my Mag T56. However, the ceramic coating SUCKED on the 3 sets of Hooker blackheart headers that Summit.
1967 SSRS
kv67ssrs is offline
post #9 of 12 (permalink) Old Mar 22nd, 19, 03:23 PM
Garth
X3 for the Holley swap stuff. Easiest part of the swap it did. Mounts, trans cross member and long tube headers. They sat nice and tight up in the subframe. No fab required.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
1967 R/T
2004 C5 Vert
69L48Z27 is offline
post #10 of 12 (permalink) Old Mar 23rd, 19, 09:28 AM
DT
Donny
DT's Avatar
X4 Holley. You will need many more parts before your headers. Plan accordingly!
DT is offline
post #11 of 12 (permalink) Old Mar 26th, 19, 09:00 AM
Probationer
do kooks or ARH have fitment issues? i see those being possibly the two most popular on the LS platform
minavizz is offline
post #12 of 12 (permalink) Old Apr 10th, 19, 08:11 PM
Richard
Originally Posted by dt View Post
x4 holley. You will need many more parts before your headers. Plan accordingly!
how true!
rebelbayou is offline
LS3 ? or SBC bwarren LSx Swap 126 Sep 14th, 18 06:43 PM
A BBC and raised port headers Codi Exhaust and Headers 1 May 28th, 18 03:46 AM
67 Camaro RS LS3 & T56 Swap parts lists and advice needed red67RS New Member Introductions 0 Dec 11th, 17 02:13 PM
Keep temperatures in your Camaro low with Jet-Hot Headers! carid CARiD.com 0 Nov 30th, 17 03:52 AM
