Header Gasket Preferences / Suggestions - Team Camaro Tech
Exhaust and Headers Discussion related to Exhaust systems and headers.
Sponsored by: Pypes Performance Exhaust
 2Likes
  • 1 Post By ilikeike
  • 1 Post By SoCal805
post #1 of 13 (permalink) Old Jan 26th, 20, 08:33 AM Thread Starter
Apprentice
Kenny
I'll be installing a new set of headers in the next week or so and just looking for some input on which header gaskets you have had good luck with or prefer, both the brand and the type of gasket. Iron head small block. Thanks.
Kenny
KHHZ28 is offline
post #2 of 13 (permalink) Old Jan 26th, 20, 08:43 AM
bob
Re: Header Gasket Preferences / Suggestions
I have had good luck with those that have graphite impregnated into them. I have also had good luck using Permatex Utra-Copper RTV with header gaskets as well.
bob15 is online now
post #3 of 13 (permalink) Old Jan 26th, 20, 08:57 AM
Rick
https://www.summitracing.com/search/...nifold-gaskets
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #4 of 13 (permalink) Old Jan 26th, 20, 09:21 AM
kevin
I been using Mr. Gasket dead soft aluminum gaskets
I have removed them and reused them 3 times with no leaks
flat tire is online now
post #5 of 13 (permalink) Old Jan 26th, 20, 10:38 AM
Darin
ilikeike's Avatar
I’m running the AFR recommended gasket for my heads, Fel-Pro #1405
Haven’t had any issue so far.
68Tiger likes this.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #6 of 13 (permalink) Old Jan 26th, 20, 12:46 PM
FelPro
68Tiger likes this.
SoCal805 is offline
post #7 of 13 (permalink) Old Jan 26th, 20, 02:11 PM
To maintain your exhaust gasket seal you have to maintain the clamping force of your manifold bolts. Heat cycling loosens then to the point they will fall out if you do not check them frequently. That is why you can use any exhaust gasket if you use Stage Eight header bolts.
For a SBC
https://www.stage8.com/product/8911-...ader-bolt-kit/
For a BBC
https://www.stage8.com/product/8912a...-1-inch-bolts/
Big Dave
Larger Dave is offline
post #8 of 13 (permalink) Old Jan 26th, 20, 07:11 PM
bob
A simple 35 cent star washer works just fine for header bolts and won't loosen up in time either (I am talking in years of service). Plus, the star washer is easier to install than the stage 8's.
Just a cheaper and easier alternative.......
bob15 is online now
post #9 of 13 (permalink) Old Jan 27th, 20, 08:35 AM
Jeremy
Had these on my car for about 20 years. I have taken the gaskets off several times and reused them. They also help keep the header bolts tight. Replaced the centers twice in that time, nice feature about them. I just realized they are discontinued. That sucks! https://www.holley.com/products/disc...arts/29D03BERL
Jeremy
1967 rs, 355 sbc, Pontiac 867 heads, Crower rockers, Isky roller cam, FiTech Power Adder 600, Hurst Drivelines T-56 Magnum, RAM clutch, 4.10 posi, Vision 18" wheels
wireboy355 is offline
post #10 of 13 (permalink) Old Jan 29th, 20, 06:38 PM
Mr. Gasket 7401G. Best I've used. "Aluminum Reusable Exhaust Gaskets"
1968 Z-28 Black stripes on white, 350, M22, 12bolt. WIP since August 1979
jimnecci is offline
post #11 of 13 (permalink) Old Jan 30th, 20, 05:42 AM
Percy's and Stage 8 locking bolts. No leaks and no having to go back and retighten them.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #12 of 13 (permalink) Old Jan 30th, 20, 09:32 AM
+1 on Stage 8 header bolts. They also have a alan head which allows access a box wrench or socket sometimes can't get to
FelPro header gaskets is all I have used on several SBC without issue
SoCal805 is offline
post #13 of 13 (permalink) Old Feb 1st, 20, 09:43 PM
Probationer
Michael
I'm using Mr. Gasket Copper Seal gaskets. I've had both headers loose a number of times over the past 8 years, they have always resealed perfectly.
MyRed67 is offline
