Converting to electric fans, can I reuse the same fan pulley? - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 1Likes
  • 1 Post By 68rs406
post #1 of 7 (permalink) Old Jun 9th, 18, 08:53 AM Thread Starter
Apprentice
Nick
Hey folks. As the title says, I'm converting to electric fans. Am I able to just take off the clutch fan and run the same pulley? My mechanic was telling me I need at least a cap if I eliminate the old fan but Google isn't turning up anything.
So can I just take the old fan off and go?
frogstomp427 is offline
post #2 of 7 (permalink) Old Jun 9th, 18, 09:04 AM
Jon
Re: Converting to electric fans, can I reuse the same fan pulley?
You might want to use washers on the bolts, and be sure the bolts aren't so long that they run into the water pump housing or bearing.
Other than that, just do it !!
dyno jonn is offline
post #3 of 7 (permalink) Old Jun 9th, 18, 12:18 PM
Pat
ssrocket67's Avatar
Just get some short 5/16 fine thread bolts and bolt the pulley to the water pump flange
1967 Camaro: True RS, Tribute SS, 350 290 HP, Muncie M20 4 SP, 12 Bolt Posi
ssrocket67 is offline
post #4 of 7 (permalink) Old Jun 9th, 18, 02:05 PM
Yes, with shorter bolts with washers AND lock washers (or blue loc-tite in place of locks )
68 Camaro~LSx ~all motor
post #5 of 7 (permalink) Old Jun 9th, 18, 03:21 PM
Rick
I would avoid doing it if at all possible. The factory did a good job.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #6 of 7 (permalink) Old Jun 9th, 18, 04:22 PM
Sean
Another vote for this. Just watch the length.
And donít believe the anti electric fan hype, do it properly and they work fantastic. Good fan, (factory fans from production vehicles are great) with a shroud big enough for the radiator and a proper wiring job. Thermostat is preferred.
Work like a champ!
frogstomp427 likes this.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #7 of 7 (permalink) Old Jun 10th, 18, 05:26 PM Thread Starter
Apprentice
Nick
Thanks a lot!
