Quickjack - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
post #1 of 17 (permalink) Old Mar 9th, 19, 07:27 AM Thread Starter
Probationer
Quickjack
Is anyone using a Quickjack BL-5000SLX? I purchased one and it seems too short.
Parker93555 is offline
post #2 of 17 (permalink) Old Mar 9th, 19, 08:41 AM
Re: Quickjack
By short do you mean the raised height or the frame length? I don't own one
but have been intrigued by them.
my 67' build thread:
allanjs is offline
post #3 of 17 (permalink) Old Mar 9th, 19, 08:51 AM Thread Starter
Probationer
Re: Quickjack
I mean the length. It will span from the front rear leaf spring perch to less than midway on the front sub-frame. I feel like it will be too front heavy and prone to tip forward. Iím hoping to find someone thatís using one.
post #4 of 17 (permalink) Old Mar 9th, 19, 09:33 AM
Re: Quickjack
Rico6983 posted in this thread says he uses his on a 1st and 5th gen.
You might try sending him a PM. He hasn't been on the site for 2 yrs.
https://www.camaros.net/forums/11-be...age-s4e10.html
allanjs is offline
post #5 of 17 (permalink) Old Mar 9th, 19, 09:45 AM
DT
Donny
DT's Avatar
I think this special ends soon.
DT is offline
post #6 of 17 (permalink) Old Mar 9th, 19, 09:45 AM
Re: Quickjack
Don't have one but they make the 6000 model which is 11" longer frame
if you had sub frame connectors...you could position the 5000 further forward
They also make extension rails but they only get you 6" more in length and for the cost of those you would be better off buying the 6000 which is 11" longer than the 5000
SoCal805 is online now
post #7 of 17 (permalink) Old Mar 9th, 19, 12:03 PM Thread Starter
Probationer
Re: Quickjack
Thanks for the responses and suggestions to make additional purchases...Iíve considered those too. Subframe connectors are on the planning board. However, I own the 5000 and itís set up and ready to go. Iím hoping to hear from someone thatís using one now. I canít be the only person that has this lift and 1st gen.
post #8 of 17 (permalink) Old Mar 9th, 19, 12:57 PM
Re: Quickjack
Pat (ssrocket67) has one. He's active here on TC. Send him a PM.
Here's a thread where he talks about it. Post #6. I think there's
some here that would like to hear some first hand info about these lifts.
https://www.camaros.net/forums/25-te...kwik-lift.html
allanjs is offline
post #9 of 17 (permalink) Old Mar 10th, 19, 06:31 AM
Bill
Re: Quickjack
I place it with hoses facing rear of car and put 1 large & 1 small rubber block at the front eye of leaf spring and ! large block under sub frame will be level when lifted , dont forget the vehicle will move forward when lifted
bills69 is offline
post #10 of 17 (permalink) Old Mar 10th, 19, 06:54 AM Thread Starter
Probationer
Re: Quickjack
The rear of your car is higher too? Iím easily 3 inches higher in the back. I contacted Quickjack and ask how to lift when it wasnít level...they want pictures and measurements. So you use the leaf spring perch rather than the subframe just inboard of the bracket and put the front block on the subframe. Does it seem front heavy or is it stable?
post #11 of 17 (permalink) Old Mar 11th, 19, 05:36 AM
Bill
Re: Quickjack
stable doing exhaust now
bills69 is offline
post #12 of 17 (permalink) Old Mar 22nd, 19, 09:11 AM
Pat
ssrocket67's Avatar
Re: Quickjack
Mine is a little higher in the back as well so I use higher blocks in the front which levels it out. I have a 7000 and use the SUV style blocks that they sell. Since I have subframe connectors, the rear blocks will rest on the connectors where they meet the forward spring eye, the front will reach the flat part of the front subframe, just rear of the curved portion.
The lift is very stable. The reason I bought a 7000, is because I also use it on my 2017 Colorado, the frame is even longer on that, and it supports it just fine.
Another way to place the lifts is perpendicular to the frame (one lift for the rear and one lift for the front). When lifting the car will move to the side.
1967 Camaro: True RS, Tribute SS, 350 290 HP, Muncie M20 4 SP, 12 Bolt Posi
ssrocket67 is offline
post #13 of 17 (permalink) Old Mar 23rd, 19, 04:41 AM Thread Starter
Probationer
Re: Quickjack
Thanks for the information. I think lifting sideways is going to be my best option until I can get frame connectors installed OR buy the longer lift. I bought this one for a couple of reasons; Bought at Costco for 1k and they back it forever, itís short enough that the lift wonít interfere when working on the front end.
post #14 of 17 (permalink) Old Mar 24th, 19, 12:40 AM
Probationer
NO
Re: Quickjack
It's not too short, as I have been using the same QJ model for a '67.
Rear jack point is on the shackles and the front jack point is on the rails.
Even if it was too short, which it's not, you just need to get the car up and with the lock arms and jack stands that you should always use, will keep the car up with no issues.
I use one jack stand in the rear on the pumpkin and 2 in the front under each control arm.
It does take some time to trust the QJ....but that will pass as long as you use jack stands. ALWAYS USE JACK STANDS
VIVII is offline
post #15 of 17 (permalink) Old Mar 24th, 19, 07:09 AM
Lyle
Re: Quickjack
I actually went to the Costco website and had a look after reading this thread, but now I'm kind of wondering if you still need safety stands (and I'm not arguing that you don't) then what is the benefit? I can use my floor jack front and rear to lift the car fairly quickly to get the stands under it, so how would this be of benefit unless I didn't use safety stands?
thebat is offline
