New Steering Wheel - Dead Battery? - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 8Likes
post #1 of 21 (permalink) Old Mar 17th, 19, 12:06 PM Thread Starter
Rusty
Hey guys,
I just installed a new Grant Steering wheel in my 1969 Camaro and a couple of days later the battery is dead. The horn functions correctly. It must be shorting out somewhere but wouldn't the horn be blowing? I'm not really good with electric. Any suggestions are appreciated.
Rusty
RustyC is offline
post #2 of 21 (permalink) Old Mar 17th, 19, 12:47 PM
Re: New Steering Wheel - Dead Battery?
You would think the horn would be blowing but with you saying it functions correctly, I'm guessing you have tried it after charging the battery back up ?.
Who's to say what's going on and we could guess at things but check for the obvious. Does the dome light go off when the doors are shut, could the glove box light be on, was the trunk or hood left open and it possibly having a mercury switched light, was it on or even if it was closed, was the car parked at a goofy angle while the steering wheel was replaced and then left parked there to where the light was on and needs to be adjusted properly ?.
If all else fails you may have to get out a meter to check for draw.
Who knows something might have broke and just decided to happen at the same time as the steering wheel replacement.
RustyC likes this.
SOA-Nova is offline
post #3 of 21 (permalink) Old Mar 17th, 19, 12:58 PM
69-Pace's Avatar
Exclamation Re: New Steering Wheel - Dead Battery?
Hum sounds like a great bug hunt is afoot.
I would double check the turn signal/hazard switch for any pinched wires and see if there is a short there first.
If it was the horn then yes the relay would be clicking if the horns are dead or not connected or grounded, when you put positive battery cable back on battery, or if connected and in working order blowing the horn outright.
Also check your wiring connection "harmonica" on the steering column, something may have dislodged and is causing a short. You may need to meter all the connections to find it.
RustyC likes this.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 21 (permalink) Old Mar 17th, 19, 04:44 PM
Kevin
If you suspect its the horns, disconnect them from their relay. This would then verify that they indeed are what are discharging the battery.
RustyC likes this.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #5 of 21 (permalink) Old Mar 17th, 19, 05:21 PM Thread Starter
Rusty
SOA-NOVA, All the lights seem to be working properly. I have a small cheap meter. Do you know what to set the meter on to check for draw?
RustyC is offline
post #6 of 21 (permalink) Old Mar 17th, 19, 05:36 PM Thread Starter
Rusty
Brian, I don't know where to start looking for the turn signal/hazard or the wiring connection "harmonica". Is that difficult to explain or maybe I can find a video on YouTube? Also, I don't know what to set a meter on to test.
RustyC is offline
post #7 of 21 (permalink) Old Mar 17th, 19, 05:42 PM Thread Starter
Rusty
Bucko, That's a good idea. If it's the horns and I unplug them then the battery shouldn't drain. That's the easiest place to start. Thanks
RustyC is offline
post #8 of 21 (permalink) Old Mar 17th, 19, 06:12 PM
If itís the horns disconnecting them will not prevent the horn relay from draining the battery...
Unplug the horn relay.
1959 El Camino project
1969 Z28 factory air project
- sold
dhutton is offline
post #9 of 21 (permalink) Old Mar 17th, 19, 06:12 PM
Originally Posted by RustyC View Post
Hey guys,
Rusty
Can you right now, go out and make the horn sound by pushing the horn button in on the new Grant steering wheel and then have them stop sounding once you let off of the horn button i?.
You said they are working but just want to make sure to keep things straight.
SOA-Nova is offline
post #10 of 21 (permalink) Old Mar 17th, 19, 06:36 PM
Vega$69's Avatar
Perhaps the bad battery is just a Coincidence and has nothing to do with replacing the steering wheel
RustyC and Old Dad's 67 like this.
66 Chevelle Protour LS3/525SOLD at Mecum 2018
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #11 of 21 (permalink) Old Mar 17th, 19, 07:24 PM Thread Starter
Rusty
Jim,
Yes, the horn blows when the horn button is pushed and stop when released.
Rusty
RustyC is offline
post #12 of 21 (permalink) Old Mar 17th, 19, 07:57 PM Thread Starter
Rusty
John,
I would have considered a bad battery but the battery is only 6 months old. I keep it on a battery tender. The battery will be easy to test and rule out. Thanks.
Rusty
RustyC is offline
post #13 of 21 (permalink) Old Mar 17th, 19, 08:03 PM Thread Starter
Rusty
Don,
I am not familiar with a horn relay. Do you know where it would be located? Can I just trace wires from the horns?
Rusty
RustyC is offline
post #14 of 21 (permalink) Old Mar 17th, 19, 08:19 PM
Vega$69's Avatar
If itís the horn relay the horn would be going all the time and would not just honk and stop when the horn button is pushed.
Interior lights not turning off when doors are shut? Glove box light staying on? Brake lights switch and brake light stay on?
RustyC likes this.
Vega$69 is offline
post #15 of 21 (permalink) Old Mar 17th, 19, 09:02 PM
Nick
it could be that you left the door open for to long doing the re and re and killed the battery. some batterys are done once the go dead even for one time
RustyC likes this.
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
Tags
dead battery, horn, steering wheel
Battery relocation to the trunk Just 1 More Electrical & Wiring 59 Oct 2nd, 18 11:12 AM
Tilt steering column with Deluxe wheel thewebb1 Brakes, Suspension & Steering 18 Jul 30th, 18 04:53 PM
MOMO Steering Wheel Project Redux 57vette Interiors 4 Apr 27th, 18 06:01 PM
EDIT MOMO Steering Wheel Project 57vette Edit Forum 17 Dec 28th, 17 06:14 AM
MOMO Steering Wheel Project 57vette Interiors 15 Nov 27th, 17 05:18 PM
