Sniper EFI / Tank setup - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
post #1 of 5 (permalink) Old Mar 22nd, 19, 08:10 PM Thread Starter
Within the next few weeks i am looking to purchase a Sniper EFI kit. Currently thinking about whether I should go with the master kit or the standard kit.
My understanding is that the master kit negates the need for a new tank...?
My future plans also include a nitrous plate system. So, I am wondering if I should maybe just put a sump on my original tank being that I will then need 3 fuel ports? EFI feed, EFI return, N20 feed?
Thoughts?
68 SS 357, AFR195, Hotchkis, TKO600, 3:73
Miikeremains is offline
post #2 of 5 (permalink) Old Mar 25th, 19, 05:47 AM
George
Re: Sniper EFI / Tank setup
I used the Tanks Inc kit with the cutout corners (helps for mini-tubs). Saves a bunch of time. Matt's Classic gets the setup for a great price. Also has the benefit of being an in tank pump. Cooler and quieter.
1967-68 Notched Corner Chevy Camaro and Pontiac Firebird Fuel Tank - For Fuel Injection
This is the setup in my 69: https://www.camaros.net/forums/133-b...post1783095381
George
69 Base V8 Coupe (purchased in 1988)
Build Thread:
gkala is offline
post #3 of 5 (permalink) Old Mar 26th, 19, 08:17 AM
Josh
I went with the Holley in tank pump for the 1 gen Camaro with a stock tank. I liked that it had a built in regulator so no need for a return line to be run back.
68 Z/28
383, M-20, 8.5 w/ 3.73's
jcihos is offline
post #4 of 5 (permalink) Old Apr 14th, 19, 07:03 PM
Probationer
I recently purchased a hyperfuel 440 set up for my 69. It comes with the tanks inc. tank. Pretty nice but I will require a return. I am still waiting on parts to complete it but I will have the 4500 sniper stealth with 250 dry nitrous.
xdr1967 is offline
post #5 of 5 (permalink) Old Apr 14th, 19, 11:04 PM
Probationer
Thoughts?
How much power is your combination going to make... Id just use one big pump and be done with it. Check out the HyperFuel 440 deal..
xdr1967 is offline
My Holley Sniper EFI / Hyperspark Experience OUTarHeel EFI in your modern Classic 5 Mar 30th, 19 02:22 PM
FiTech EFI Throttle Bodies and LS Swap Harness/Computers! MCB Sponsors 1 Jan 10th, 19 01:18 PM
427 sbc with Sniper EFi headaches Greg Katsap Engine 7 Dec 31st, 18 04:33 AM
EFI w/over 253 .050" cams - Sniper, Stealth Terminator, Pro Flo 4 stantaur Engine 5 Nov 16th, 18 03:01 PM
BLACK FRIDAY NOW! FiTech EFI Systems and LS Kits MCB Sponsors 0 Nov 12th, 18 12:16 PM
