key won't turn to open the trunk. - Page 2 - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 3Likes
post #16 of 28 (permalink) Old May 15th, 19, 04:46 PM Thread Starter
Apprentice
Re: key won't turn to open the trunk.
Thanks guys for the quick replies I just tried to turn the lock shaft from inside the trunk with no success Looks like if I remove the three bolts to the lock mechanism the shaft would still hold it in place??? I don't mind drilling the lock but can you be more descriptive on the drilling??? Would I try to drill out the whole internals of the tumbler?? Thank you
jrunner is offline
post #17 of 28 (permalink) Old May 15th, 19, 05:21 PM
Garth
hmm, I forget how the shaft attaches to the cylinder...I don't think much holds it. Maybe a spring ? Here's a pic .https://www.heartbeatcitycamaro.com/...Kit-w-GM-Keys/
If you can pull the shaft from the cylinder to disengage, then turn the shaft...
For the 3rd time; HAVE YOU TRIED LUBING THE CYLINDER ??
Garfields Maro is offline
post #18 of 28 (permalink) Old May 15th, 19, 05:33 PM Thread Starter
Apprentice
Oh yes sorry first thing I sprayed wd 40 the first night then in the mourning its a new lock I installed a few years ago I also tried pushing down and pulling up on the lid
jrunner is offline
post #19 of 28 (permalink) Old May 15th, 19, 05:34 PM
Vega$69's Avatar
The shaft engages the lock with like a 1/4 turn. I believe it will turn. The key in the lock may help.
Vega$69 is offline
post #20 of 28 (permalink) Old May 15th, 19, 05:58 PM
69-Pace's Avatar
unscrewing the bracket as Everett suggests is the quickest fix for your issue IMHO. https://www.camaros.net/forums/1783139275-post8.html The bracket Everett speaks of is NOT visible in the photo Patrick posted. It's dark here so I can't grab a decent one off my car tonight but if still an issue I will.
It is a tight fit, Unless you own a convertible then you can sacrifice the top well and get into the trunk with relative ease. Your signature block in your profile is missing your vehicles details so I throw this out there in case it is the case.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #21 of 28 (permalink) Old May 15th, 19, 07:28 PM
Vega$69's Avatar
Honestly at this point I'd drill the lock and be done with it in 2 minutes.
66 Chevelle Protour LS3/525SOLD at Mecum 2018
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #22 of 28 (permalink) Old May 15th, 19, 08:03 PM
Beth
Just keep the drill centered where you insert the key. I think my drill bit tended to wander downward so go slow and keep it straight.
Don't go in more than 1-1/2"
I started with a 3/16" and ended with a 5/16"
Then inserted flat blade screwdriver and opened it
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #23 of 28 (permalink) Old May 15th, 19, 08:57 PM Thread Starter
Apprentice
Wow that was simple thanks guys for all the support. Nervously I drilled it out like some suggested can't go wrong now I do see the bracket and bolt for the lock Everett suggested but also there was no way my fat *** would be able to reach it I already installed the old original trunk lock works great. Thank you.
Garfields Maro likes this.
jrunner is offline
post #24 of 28 (permalink) Old May 15th, 19, 09:27 PM
Garth
If it isn't dinged, the original stainless bezel will polish out better than new.
post #25 of 28 (permalink) Old May 17th, 19, 09:48 PM Thread Starter
Apprentice
Huh how did you know? It actually has three little dings in it sprayed with wd 40 can really tell the difference between factory mechanism and cheapo aftermarket.
jrunner is offline
post #26 of 28 (permalink) Old May 18th, 19, 12:45 AM
Garth
Why else would one replace a perfectly good lock ? A few years ago, repro bezels were available, but I looked around a little just now and couldn't find them. I replaced my trunk lock bezel that way. How 'bout the repro lock you drilled out. Is the bezel salvageable ? Working a small screwdriver around on the back side, you can pry the bezel loose, then crimp it back down on the other lock...
post #27 of 28 (permalink) Old May 18th, 19, 08:00 AM
scblucam's Avatar
Brings to mind an incident long ago. Friend Mike thought he locked his keys in the trunk of his Chevelle. In frustration finally took a claw hammer to the trunk lid. Got it opened and found his keys. ....... In his pocket.
68 302 M20 - 85 IROC Z
scblucam is offline
post #28 of 28 (permalink) Old Today, 05:41 AM
Kevin
Lightbulb Re: key won't turn to open the trunk.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
Open trunk and glove compartment without key? 68sik1 Camaro Tech 7 Mar 13th, 10 09:02 PM
how to open the trunk from inside...95 camaro zimmyjim Fourth Generation 6 Jul 5th, 09 07:01 PM
turn the key and hear '' click'' peteys68 Electrical & Wiring 7 Mar 5th, 08 07:08 PM
Does "brake" idiot light come on when you turn the key?? dschribs Engine 2 May 22nd, 05 09:02 PM
