Engine temp ?? - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 17Likes
post #1 of 50 (permalink) Old Jun 3rd, 19, 11:16 AM Thread Starter
Frank
Engine temp ??
i'm running a 180* t-stat and so far after a couple trips around town, idling at red lights, even had to wait for a big group of school kids to cross the road i'm staying 185*-195*ish.. sound ok to you guys?
Ran it for an hour yesterday on some good twisty roads and hit it pretty hard and still stayed around same temps.
'68 Camaro 454, 4sp
Just 1 More is offline
post #2 of 50 (permalink) Old Jun 3rd, 19, 11:41 AM
Re: Engine temp ??
nothing wrong with those temps
Just 1 More likes this.
SoCal805 is online now
post #3 of 50 (permalink) Old Jun 7th, 19, 05:46 AM
jeff
Re: Engine temp ??
Factory stat was 195*
jkuro is offline
post #4 of 50 (permalink) Old Jun 7th, 19, 09:13 AM
kevin
Re: Engine temp ??
I am running a 160* thermostat and my temperature stays at 175*- 180*
flat tire is offline
post #5 of 50 (permalink) Old Jun 7th, 19, 09:28 AM
Re: Engine temp ??
And remember, gauges, sensors, etc., are not calibrated - do you see a cal sticker?
Only for an indication - our viewing pleasure as shown in Off-Topic - Rear Ends
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
post #6 of 50 (permalink) Old Jun 7th, 19, 02:33 PM Thread Starter
Frank
Re: Engine temp ??
Did an 80 mile round trip to the office and a couple side stops, mostly interstate, drove it to lunch.. no issues.. stayed between 185 and 198. Drank 8 gallons of gas
flat tire likes this.
'68 Camaro 454, 4sp
post #7 of 50 (permalink) Old Jun 7th, 19, 03:29 PM
Re: Engine temp ??
10mpg....must be nice
Glad its under control
68 Camaro~LSx ~all motor
post #8 of 50 (permalink) Old Jun 7th, 19, 04:25 PM
scblucam's Avatar
Re: Engine temp ??
My motor runs kind of ragged until it hits 200*. Not real happy below that.
68 302 M20 - 85 IROC Z
scblucam is offline
post #9 of 50 (permalink) Old Jun 7th, 19, 05:50 PM
Rufas
Re: Engine temp ??
"'68 Camaro 454, 4sp" Cast iron block, cast iron heads, engine temp should be 180 deg/F. and stay there.
What, if any mods to the cooling system, like electric fans, no fan shroud, under drive pulleys, flex fan?
Also, any mods to the ignition timing settings, vacuum advance, mechanical, initial? This can also cause engine heating variations.
dave ray is offline
post #10 of 50 (permalink) Old Jun 8th, 19, 12:46 PM
kevin
Re: Engine temp ??
I am not that smart so I rely on books. according to Chilton's motor manual I see no 454 engine for a 68 camaro. maybe there was a misprint . I don't know.
was there a 454 engine for a 68 camaro?
if not there could be several things that could alter the temperature of the above post of 180* and stay there
since there I could find no listing for a 454 in a 68 camaro, one would assume the grill opening, radiator size. size and type of fan and etc. would play an important part on the degree of cooling.
although I am no expert or have worked for GM I believe your temperature readings are ok
THIS IS JUST MY OPINION
post #11 of 50 (permalink) Old Jun 8th, 19, 01:13 PM
Red face Re: Engine temp ??
The 454 was introduced in 1970. No first gens stock as a 454. They were 396's and a few 427's !
TJS69 is offline
post #12 of 50 (permalink) Old Jun 8th, 19, 01:25 PM
Re: Engine temp ??
If you look at Frank's signature you'll see he has a 454 in his 68.
my 67' build thread:
allanjs is offline
post #13 of 50 (permalink) Old Jun 9th, 19, 01:22 PM Thread Starter
Frank
Re: Engine temp ??
454 std bore, 600 lift hyd roller cam, lifters, rockers, Alum rad, 18" Rev rotation fan, Rev Rotation fan clutch, BB shroud, Rev rotation waterpump as part of the serp belt system,,,,, NOTHING is stock in this thing
20190429_164815_001 by F G, on Flickr
20190504_115558 by F G, on Flickr
20190504_115615 by F G, on Flickr
'68 Camaro 454, 4sp
post #14 of 50 (permalink) Old Jun 9th, 19, 03:40 PM
Rufas
Re: Engine temp ??
I'd add to it a 30 percent anti-freeze/70 percent tap water mix. Water conducts heat a lot more efficienltly than anti-freeze, and higher concentrates of A/F only reduce the cooling conductivity of the water by reducing the volume of it i the mix.
As far as tap water, I do not use de-mineralized waters, and that is what most altered waters are. A de-mineralized water is, of course, mineral starved, and will eat minerals, like cast iron, aluminum, gaskets, etc. Even with a sacrificial anode, the level of engine parts erosion is high. Another thing I do is run a very specific type of thermostat, used to be available under the Mr. Gasket, and Robertshaw brands as a "pressure balanced" 'stat. These have a barrel shaped valve in them, instead of a flat plate, which can be forced shut at higher flow volumes.
Your system looks set up nicely, It should work well.
dave ray is offline
post #15 of 50 (permalink) Old Jun 9th, 19, 08:45 PM
Vega$69's Avatar
Re: Engine temp ??
I would you distilled over tap water. Like he 30% and 50/50 is not ideal for the way most of us keep and drive our classics. 30% will cool better and still yield good corrosion protection and water pump lube.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
