Clutch Pedal Firewall Air Flow - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
post #1 of 10 (permalink) Old Jun 16th, 19, 02:57 AM Thread Starter
Todd
I have a ton of hot air coming through tne firewall where the clutch pedal goes through. I'd like to tighten it up to help the A/C stay cooler. We already tried a replacement of the rubber bushing/grommet but that's a fix that doesn't last but a month. I don't know if the hole is larger than it should be but you can easily see daylight. Has anyone else had a similar problem and come up with a solution?
CityguyUSA is offline
post #2 of 10 (permalink) Old Jun 16th, 19, 04:52 AM
Re: Clutch Pedal Firewall Air Flow
Never had a problem in decades using the correct boot for the factory hole. https://www.camarocentral.com/1967_1...l_p/clu-15.htm
Call for restoration and custom paint scheduling:
Sauron67MM is offline
post #3 of 10 (permalink) Old Jun 16th, 19, 05:43 AM
DT
Donny
DT's Avatar
X2. Sounds like you might have a butchered hole or incorrect boot. A boot was used, NOT a grommet.
DT is offline
post #4 of 10 (permalink) Old Jun 16th, 19, 05:57 AM
keith
X-77 keith's Avatar
My car was finished about a year ago. I have replaced the boot twice since then. Bought them both from different vendors. The top keeps ripping off. Like they are dry rotted. Even put some superlube on the rod to help it slide. Just going to deal with it now.
X-77 keith
X-77 keith is offline
post #5 of 10 (permalink) Old Jun 16th, 19, 07:56 AM
kevin
all their rubber products must be rotten. I too give up on the clutch rod boot after replacing it twice along with the shifter boot that I replaced 4 times
flat tire is offline
post #6 of 10 (permalink) Old Jun 16th, 19, 07:53 PM
Chris
The boots are junk, I gave up on them years ago, they all tore no matter what I tried.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #7 of 10 (permalink) Old Jun 17th, 19, 10:23 AM
Jeremy
I quit using the one for a 67-69 Camaro because it kept ripping. Tried a few different brands. The fix for me was a boot for a 70 and up Camaro. Its been holding up great for over a year. GOODMARK GMK4021951705 https://www.rockauto.com/en/catalog/...rod+seal,11029
Jeremy
1967 rs, 355, pontiac 867 heads, crower rockers, Isky roller cam, FiTech Power Adder 600, Hurst Drivelines T-56 Magnum, RAM clutch, 4.10 posi, Vision 18" wheels
wireboy355 is offline
post #8 of 10 (permalink) Old Jun 17th, 19, 07:06 PM
keith
X-77 keith's Avatar
I have thought of those. Might try one this fall.
X-77 keith
post #9 of 10 (permalink) Old Jun 20th, 19, 05:14 PM
Have replaced my boot with reproduction. It is holding up but didn't fix the hot air. I found, while having the engine out, the steering column seal loose with a big gap. Fixed it with some sealing compound and the hot air is gone.
1968 Z-28 Black stripes on white, 350, M22, 12bolt. WIP since August 1979
jimnecci is offline
post #10 of 10 (permalink) Old Jun 21st, 19, 12:21 PM
Pete
Do you have the correct cover and seal for the steering column? I replaced mine when I swapped out the original column for a tilt. I don't see how any air can get through that thing....
68lowered is offline
