Horn relay - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 3Likes
post #1 of 18 (permalink) Old Jun 23rd, 19, 08:14 AM Thread Starter
R/T
Jack
Horn relay
My horn relay no long sounds when my car door open.
How can I restore the relay. It is original so I don't want to replace it. Can they be rebuilt.
Matthew 22: 37-39
R/T is offline
post #2 of 18 (permalink) Old Jun 23rd, 19, 08:23 AM
Vega$69's Avatar
Re: Horn relay
Why do you think it's the relay and not the key buzzer in the column?
Vega$69 is offline
post #3 of 18 (permalink) Old Jun 23rd, 19, 12:07 PM
Pat
Re: Horn relay
Ages ago my fatherís car stopped doing the warning buzzer thing, turned out the key had worn down just enough that it no longer triggered it. Different key worked fine...
Pat - 68 Camaro Coupe -
patman2 is offline
post #4 of 18 (permalink) Old Jun 23rd, 19, 01:22 PM
69-Pace's Avatar
Exclamation Re: Horn relay
If you are getting signal on the key minder wire at the relay but no buzz, gently tap the unit with a rubber mallet. It just may be gunked up. Other wise you have to take the top off and rebuilt it, may need some adjustment to buzz. Does the horn still sound?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #5 of 18 (permalink) Old Jun 23rd, 19, 02:08 PM
Lee
Re: Horn relay
Easy enough to check. Just probe the pink/black wire at the horn relay. With key in door closed it should be 12V with door open it should go to ground.
R/T likes this.
blitzer454 is offline
post #6 of 18 (permalink) Old Jun 24th, 19, 01:47 PM Thread Starter
R/T
Jack
Re: Horn relay
Did not think of that
Matthew 22: 37-39
R/T is offline
post #7 of 18 (permalink) Old Jun 24th, 19, 01:48 PM Thread Starter
R/T
Jack
Re: Horn relay
Originally Posted by 69-Pace View Post
If you are getting signal on the key minder wire at the relay nut no buzz, gently tap the unit with a rubber mallet. It just may be gunked up. Other wise you have to take the top off and rebuilt it, may need some adjustment to buzz. Does the horn still sound?
Yes the horns work
Matthew 22: 37-39
R/T is offline
post #8 of 18 (permalink) Old Jun 24th, 19, 02:19 PM
69-Pace's Avatar
Re: Horn relay
Originally Posted by R/T View Post
Yes the horns work
Yeah, then its more than likely the key minder switch as others have stated. Once you test the lead you will know where the issue is.
69-Pace is offline
post #9 of 18 (permalink) Old Jun 29th, 19, 06:05 AM Thread Starter
R/T
Jack
Re: Horn relay
Where is the key minder switch ??
Matthew 22: 37-39
R/T is offline
post #10 of 18 (permalink) Old Jun 29th, 19, 09:10 AM
Lee
Re: Horn relay
It's in the steering column, refer to this thread.
post #11 of 18 (permalink) Old Jul 11th, 19, 05:27 PM Thread Starter
R/T
Jack
Re: Horn relay
I tested the horn replay buzzer by touching the two contact pads on the back of the turn signal switch. The buzzer worked. I pulled out the key buzzer switch to test it. It was fine. I reinstall the buzzer switch. Put the key and get nothing(ohm test). Any help on what to check next...
Matthew 22: 37-39
R/T is offline
post #12 of 18 (permalink) Old Jul 11th, 19, 07:50 PM
Gary
69Z28's Avatar
Re: Horn relay
How worn out is the key? The keys on my car were pretty worn, and my Z had the same issue when I first bought it. I had all my locks rebuilt with new keys and didn't do anything else, and all was working. I'm not so sure here, but I'm guessing the front tip gets shaved smooth after going thru the in and out motions (LOL) all these years, and just doesn't PUSH the buzzer switch contacts together.
Hey, did that sound a little suggestive and dirty? I'm still chuckling after rereading that. LOL
06A 1969 Camaro Z28
X33D80 69 B 711 Black Stripes
Console w/tach and gauges.
69Z28 is offline
post #13 of 18 (permalink) Old Jul 12th, 19, 04:14 PM
Jeff
yellow69RS's Avatar
Re: Horn relay
Pull the lock cylinder out of the column. reassemble the ts switch to the column and use a small pick or srewdriver push up on the Key minder switch thru the opening where the lock used to be. If it buzzes look at the cylinder with key in and out to be sure the button is working to press the switch. IF it doesn't buzz the problem is the key switch contacts are not hitting the back of the T/S switch
yellow69RS is offline
post #14 of 18 (permalink) Old Jul 12th, 19, 06:58 PM Thread Starter
R/T
Jack
Re: Horn relay
[quote=69Z28;1783151027]How worn out is the key? The keys on my car were pretty worn, and my Z had the same issue when I first bought it. I had all my locks rebuilt with new keys and didn't do anything else, and all was working. I'm not so sure here, but I'm guessing the front tip gets shaved smooth after going thru the in and out motions (LOL) all these years, and just doesn't PUSH the buzzer switch contacts together.
I tried a new set of keys. No change
Matthew 22: 37-39
R/T is offline
post #15 of 18 (permalink) Old Jul 12th, 19, 07:00 PM Thread Starter
R/T
Jack
Re: Horn relay
I'll try this tomorrow
yellow69RS likes this.
Matthew 22: 37-39
R/T is offline
