No dash lights.. will there be juice on test light on Grey wire from h - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 1Likes
  • 1 Post By SoCal805
post #1 of 15 (permalink) Old Jul 11th, 19, 08:40 AM Thread Starter
Apprentice
No dash lights. Checked fuses, bulbs, reostate switch turned and grounded the instrument cluster in few areas to make sure that was grounded. I get turn signal lights etc. also get juice from pink wire from harness.
I’m tracing the instrument light GREY wire to harness.....any way to tell if that wire or the black are good?
69camaro! is offline
post #2 of 15 (permalink) Old Jul 11th, 19, 09:02 AM
Re: No dash lights.. will there be juice on test light on Grey wire fr
Yes the grey wire powers the dash lights and should be hot when the light switch is pulled
out and the rheostat turned. Probing the grey wire to ground should show power variable
depending on the rheostat position. At least that's the way it works on a 67. I think all
1st gens are the same. There are some videos on youtube showing how to test the switch.
my 67' build thread:
allanjs is offline
post #3 of 15 (permalink) Old Jul 11th, 19, 09:48 AM
I guess you are dealing with a 69 Camaro ?.
While I do not have diagrams for a Camaro, on the 69 Nova you have a green wire off of the headlight switch that then goes to the fuse block and then past the fuse the wire color turns to a gray.
You could wire up a jumper wire from a fused 12V source in the fuse block and touch it to the gray wire in the instrument panel plug and if it the dash lights come on then you probably have an issue off of the gray wire or the possibly green wire off of the headlight switch.
You can also use a voltmeter to check for power and/or ground.
SOA-Nova is online now
post #4 of 15 (permalink) Old Jul 11th, 19, 10:46 AM Thread Starter
Apprentice
Thanks Jim! I’m at Napa currently gonna replace headlight switch. Maybe retostathe. I’ll try that too
post #5 of 15 (permalink) Old Jul 11th, 19, 11:01 AM Thread Starter
Apprentice
So I tried the jumper from green to grey and nothing happened.... so maybe the headlight switch itself ?
post #6 of 15 (permalink) Old Jul 11th, 19, 11:15 AM Thread Starter
Apprentice
My parking brake fuse keeps blowing
post #7 of 15 (permalink) Old Jul 11th, 19, 11:16 AM Thread Starter
Apprentice
Parking light fuse
post #8 of 15 (permalink) Old Jul 11th, 19, 11:20 AM
Does the green have power ?. If not, then connecting it to the gray will not turn the lights on.
post #9 of 15 (permalink) Old Jul 11th, 19, 12:21 PM Thread Starter
Apprentice
Yes. Has power from that green wire. When adding green wire to grey via jumper it’s pops the parking light 10amp fuse
post #10 of 15 (permalink) Old Jul 11th, 19, 12:28 PM
maybe the green wire going into back of INST fuse on fuse block (grey wire coming out) is making contact with the tan +12v wire of the PB switch
SoCal805 is offline
post #11 of 15 (permalink) Old Jul 11th, 19, 12:42 PM Thread Starter
Apprentice
Maybe since dropping the steering column? I’m getting -10.5 A on multimeter readings on all bulbs. They just worked before I removed the instrument housing
post #12 of 15 (permalink) Old Jul 11th, 19, 12:52 PM Thread Starter
Apprentice
Okay. So that green wire from harness to grey on back of connection grey wire dash lights work!!! When I touch green wire to grey wire on other side of connector my fuse pops. What does this mean?
post #13 of 15 (permalink) Old Jul 11th, 19, 02:01 PM Thread Starter
Apprentice
Green wire to grey dash light wire on connecting harness Lights work!! Now with light harness fully connected grey one side to grey the other and with headlight switch pulled (brand new headlight switch) No lights work and in fact the dash light 10A fuse blows.
I’m confused what to do next?
post #14 of 15 (permalink) Old Jul 11th, 19, 02:17 PM
you have a hard ground short on the grey wire post fuse panel. Some dash light somewhere is grounding.
probe each one at every bulb continuity to ground (don't have light switch or key on). If you get continuity from ground to grey wire anywhere....you found the problem
yellow69RS likes this.
SoCal805 is offline
post #15 of 15 (permalink) Old Jul 11th, 19, 08:01 PM
Iím confused what to do next?
First off, this 10A fuse that blows, is it the very short one in the fuse block down low ?. I don't think it should be that large and I'm thinking it should be a 4A or 5A BUT we may be talking about a different fuse. Can toy take a picture of the fuse block and highlight the location of the fuse that is blowing ?.
Like SoCal805 stated, it sounds like a dead short and it may be on the dash light circuit or possibly the parking lights. This is why I'm asking what fuse blew. It seems to me that on the Nova headlight switch you have two battery feed wires to the headlight switch with one of the two being a smaller gauge wire and protected by a fuse in the underdash interior fuse block. GM years ago tied multiple things together and we just need to stay together here to figure out if one fuse is blowing and if it is before the headlight switch or downstream past the headlight switch and protecting the dash light circuit.
