What's the gear ratio???? - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 9Likes
post #1 of 19 (permalink) Old Jul 16th, 19, 03:42 PM Thread Starter
Frank
Ok math guru's
70 mph @ 2750 rpm's
Tires are 255/45-18's
Diameter inches 27.04"
Circum. inches 84.93"
Revolutions per mile 745.99
'68 Camaro 454, 4sp
Just 1 More is offline
post #2 of 19 (permalink) Old Jul 16th, 19, 03:53 PM
Re: What's the gear ratio????
...ah not a math wiz but if you jack up rear of car, put a mark on DS, with trans in neutral rotate tire 1 revolution and cound how many times the DS rotates.
just a little over 3 turns is 3:08, 3 1/2 turns 3:55, 3 3/4 turns 3:73, etc
looks like you would have 3:08's
use this calculator and enter your 411
https://spicerparts.com/calculators/...rpm-calculator
Just 1 More likes this.
SoCal805 is offline
post #3 of 19 (permalink) Old Jul 16th, 19, 04:47 PM
2.73's or 3.08's I'd guess.
68 Camaro~LSx ~all motor
post #4 of 19 (permalink) Old Jul 16th, 19, 05:02 PM Thread Starter
Frank
I was figuring 3:08's.. going to be a big change when i do the 3:55's
'68 Camaro 454, 4sp
post #5 of 19 (permalink) Old Jul 16th, 19, 06:04 PM
Just a few hundred rpm more (500 or so)
post #6 of 19 (permalink) Old Jul 16th, 19, 06:15 PM
Vega$69's Avatar
Yes. Calcs to 3.08
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #7 of 19 (permalink) Old Jul 17th, 19, 04:07 AM
kevin
26" tire, 3:55 rear at 60 mph I am turning 2600 rpm in 4th gear. BUT, when I shift into 4th overdrive I can run 80 mph at 2600.
sorry I don't have any records for 70 mph in 4th, but 4th in OD is 2300
flat tire is offline
post #8 of 19 (permalink) Old Aug 28th, 19, 01:46 PM Thread Starter
Frank
It jumped to 70 mph @ 3170 rpm from the 70 mph @ 2750 rpm's so not quite 500rpm but definitely a noticeable difference .. Now I need a GVOD
'68 Camaro 454, 4sp
post #9 of 19 (permalink) Old Aug 28th, 19, 03:54 PM
420rpm....so close
post #10 of 19 (permalink) Old Oct 12th, 19, 02:16 PM Thread Starter
Frank
Ok math guru's
70 mph @ 2750 rpm's
Anyone have a good guesstimate where I would be with the Gear Vendors over drive?
'68 Camaro 454, 4sp
post #11 of 19 (permalink) Old Oct 12th, 19, 05:28 PM
Vega$69's Avatar
$2800 lighter in the wallet.
bhodgdon400 and Just 1 More like this.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #12 of 19 (permalink) Old Oct 12th, 19, 07:37 PM
Beth
Tired of shifting gears ? I have a 4L80e in my Camaro with no tunnel cutting.
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #13 of 19 (permalink) Old Oct 13th, 19, 04:26 PM Thread Starter
Frank
I may ultimately end up with an automatic since my daughter will be inheriting the car but for now, I want to row this boat
'68 Camaro 454, 4sp
post #14 of 19 (permalink) Old Oct 13th, 19, 04:28 PM Thread Starter
Frank
From a facebook reply ..
Your rpm's will be 2402 at 70 in over drive with a Gearvendor.
'68 Camaro 454, 4sp
post #15 of 19 (permalink) Old Oct 14th, 19, 01:14 AM
My now 43 year old daughter loves rowing gears, and looks forward to driving my LS3-T56-3.73 rear-440hp to the tires '68 Camaro when I shuffle off this mortal coil - although she's willing to wait for as long as it takes.
Mike - '68 Camaro with lots of stuff done to it.
Mkelcy is offline
