Brake booster grommet at firewall 68 camaro? - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 3Likes
  • 2 Post By Andrew69
  • 1 Post By jasonz28camaro
post #1 of 11 (permalink) Old Oct 12th, 19, 06:33 PM Thread Starter
Jason
Is there a grommet for the brake boosters shaft at the firewall? My brake shaft has a boot over it as seen in the picture but does not seem to like to stay in the firewall hole nor does it seem to seal it. Any help would be appreciated, thanks!
jasonz28camaro is offline
post #2 of 11 (permalink) Old Oct 12th, 19, 11:19 PM
keith
X-77 keith's Avatar
You do not have a factory booster. You may have to make something. The original had like a foam ring. Don't think it would help you. Maybe a bead of seam sealer or something along those lines.
X-77 keith
X-77 keith is offline
post #3 of 11 (permalink) Old Oct 13th, 19, 06:26 AM
Re: Brake booster grommet at firewall 68 camaro?
Someone has shimmed that booster with a bunch of washers. It is normally angled up. Not sure why, maybe they are using the manual brake hole on the pedal. If the shims were gone it might seal better.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #4 of 11 (permalink) Old Oct 13th, 19, 07:35 AM
Vega$69's Avatar
Don is correct. Also with the booster shimmed the brake rod angle is not right.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 11 (permalink) Old Oct 13th, 19, 08:29 AM
Brett
I have never seen a master cylinder like that on a first gen.
Brett.....
1969 SS 396 X66 - RS Conversion - TKO600 - 3.73 Posi - Paint Code 71-LeMans Blue
Brettallen59 is offline
post #6 of 11 (permalink) Old Oct 13th, 19, 09:07 PM Thread Starter
Jason
Maybe thats why it never stopped good haha. I bought it with that master/booster setup and I plan on replacing it eventually but I'm just trying to get it running and sealled up so I dont flood the floor pan.
If the stock grommet will not work I'll just try to measure the the hole and purchase a grommet. Thanks for the input guys!
post #7 of 11 (permalink) Old Oct 14th, 19, 06:05 AM
Andrew
Andrew69's Avatar
Why not try properly mounting the booster to pull the seal against the firewall?
dhutton and bhodgdon400 like this.
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #8 of 11 (permalink) Old Oct 14th, 19, 06:27 PM
Gary
69Z28's Avatar
Wondering why all those washers. Is it possible the front edge of the MC is hitting the hood when closing and had to be adjusted? That whole set up looks long.
06A 1969 Camaro Z28 X33D80 69 B 711 Black Stripes Console w/tach and gauges.
69Z28 is offline
post #9 of 11 (permalink) Old Oct 14th, 19, 07:19 PM
keith
X-77 keith's Avatar
Probably using the spacers instead of cutting the rod. Who knows what it originally came off of. The master cylinder looks of the 70-80s era. Booster looks aftermarket.
X-77 keith
post #10 of 11 (permalink) Old Oct 14th, 19, 07:36 PM
Vega$69's Avatar
The stock 11 booster is at an angle. When you use a dual 8 its more exaggerated.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #11 of 11 (permalink) Old Oct 16th, 19, 06:21 PM Thread Starter
Jason
Maybe thats why the previous owner used the washers, I'm not around it to measure at the moment. I plan on running a new master and possibly booster once its up and running. Just a timing thing so I can also do new front disk brakes, lines and front suspension.
69Z28 likes this.
