Corvette IRS in a 1st Gen?? - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 4Likes
  • 2 Post By dhutton
  • 2 Post By Vega
post #1 of 10 (permalink) Old Nov 8th, 19, 11:01 AM Thread Starter
Frank
A guy was telling me last night that one of the Corvette IRS complete assembly fits perfectly in to a 1st gen as an almost bolt in installation. Anyone know anything about this? He thought it was the C5 Vette
'68 Camaro 454, 4sp
Just 1 More is offline
post #2 of 10 (permalink) Old Nov 8th, 19, 11:18 AM
Re: Corvette IRS in a 1st Gen??
It is six inches wider so far from an easy bolt in. This guy is putting an entire C5 drivetrain in his 69 Camaro. Stretched rear quarters.
https://lateral-g.net/forums/showthr...=52425&page=37
Your best bet for an IRS in a first gen is the Art Morrison setup. Comes with a first gen specific rear subframe. Rumor has it Speedtech will be introducing an IRS setup.
130fe and Just 1 More like this.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 10 (permalink) Old Nov 8th, 19, 11:28 AM
You can keep your uneven a-arm front suspension (aka IFS, since IRS stands for independent rear suspension), and still use the big brakes off a C5-C8 Corvette by using just the taller 'vette steering knuckles on your Camaro front clip. Because the Corvette uses a taller steering knuckle (the spindle is the stub axle that the wheel bearings ride upon), it "fixes" the steering geometry issues with the first gen Camaro. They are not a bolt in and have to be modified to fit your Camaro so they are an aftermarket item.
If you want a 'vette IRS then you are going to need to modify your Camaro because the transaxle bolts to a frame you don't have, and it is larger than the amount of room you have under your car.
Big Dave
Larger Dave is online now
post #4 of 10 (permalink) Old Nov 8th, 19, 12:11 PM
Muscle Car Metal builds a purpose built set up. Check this out... Tony is a real good guy if it's something you're interested in.
Muscle Car Metal - SPORT CHASSIS - C5 Camaro Full Frame
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #5 of 10 (permalink) Old Nov 8th, 19, 02:41 PM
Alex
I know the C4 IRS setup is as close to bolt-in for a 3rd gen as reasonably possible. Maybe he thought that one would fit the same into a 1st gen.
OP, you are aware that the C5+ IRS is a trans-axle assembly right? Great for weight distribution (I'll be going that route in a couple years) but far from "bolt-in".
1969 Pontiac Firebird
w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black w/black interior.
1992 Pontiac Trans Am GTA w/SLP Performance Package. Dark Jade Grey Metallic, grey leather, T-Tops.
anguilla1980 is offline
post #6 of 10 (permalink) Old Nov 8th, 19, 05:41 PM
Jeff
yellow69RS's Avatar
Heidt's offers this one.
https://www.heidts.com/part/67-69-an...ar-suspension/
Jeff
yellow69RS is offline
post #7 of 10 (permalink) Old Nov 8th, 19, 05:46 PM
Vega$69's Avatar
Personally I like a solid axle om my 1st Gens
R/T and Just 1 More like this.
Vega$69 is offline
post #8 of 10 (permalink) Old Nov 9th, 19, 09:07 AM Thread Starter
Frank
I have no plans to go to an IRS, I was just asking because someone told me it worked, as expected, it was BS. My plan is the Ridetech 4 link & mini tubs
'68 Camaro 454, 4sp
post #9 of 10 (permalink) Old Nov 9th, 19, 10:14 AM
Vega$69's Avatar
I would do a Torque Arm instead of a 4 Link
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #10 of 10 (permalink) Old Nov 9th, 19, 02:32 PM Thread Starter
Frank
I didn't think the torque arm would allow room for the GV overdrive unit?
'68 Camaro 454, 4sp
