1969 z28 - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
post #1 of 6 (permalink) Old Nov 19th, 19, 05:40 PM Thread Starter
Probationer
1969 z28
Can anyone tell me the orientation of the light bulbs in the instrument cluster. Turn signals , high beam Etc, And possibly a photo of the back side of the instrument cluster with orientation?
Sharples08 is offline
post #2 of 6 (permalink) Old Nov 20th, 19, 04:51 AM
Kevin
KevinW's Avatar
Re: 1969 z28
John, do you have a bulb out? You access the bulbs by taking the lens off, 4 screws each (2 upper and 2 lower). Once the lens is off you can pull the bayonet bulbs out and replace. The lens (left for speedo, right for tach) have white assemblies screwed on that have acetate strips with the "turn, brake, oil, etc" letters on them in which the bulb shines thru.
They are: left turn, fuel, brake, bright. Then: gen, temp, oil, right turn
Kevin
KevinW is offline
post #3 of 6 (permalink) Old Nov 20th, 19, 05:18 AM Thread Starter
Probationer
Re: 1969 z28
I have no speedo light and e brake light bleed over when i activate bright lights
post #4 of 6 (permalink) Old Nov 20th, 19, 12:23 PM
Kevin
KevinW's Avatar
Re: 1969 z28
AH, that is a different question!
The bulb that illuminates the gauges is under a plate which has a green acetate filter on it. Two screws get it off, I think you can replace bulb from the gauge opening (once lens is off). Take the speedo lens off and on the upper top is the black bulb plate.
For the bleed, once lens is off, inspect the white indicator lights holder (separate piece that screws in the rear of the lens). Yours might be broken, missing or the acetate labels may be askew.
Kevin
KevinW is offline
post #5 of 6 (permalink) Old Nov 20th, 19, 01:56 PM Thread Starter
Probationer
Re: 1969 z28
thanks . i would realty appreciate a photo of back side of the assembly if anyone could share
post #6 of 6 (permalink) Old Nov 20th, 19, 04:26 PM
Re: 1969 z28
John, You may find what your looking for in this thread post #8.
https://www.camaros.net/forums/23-in...rt-gauges.html
my 67' build thread:
allanjs is offline
