new cams for 1969 350 - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 1Likes
post #1 of 26 (permalink) Old Dec 7th, 19, 11:37 PM Thread Starter
hi guys
I would like to add. new cams to the 69 350
so I do no not know what cam is in the car now but I would like to get more of that classic muscle car rumble - yes I have a little bit of that and I here it mostly in the rear
I just added the pypes exhaust kit to the factory manifold that helped a bit but still not what I know it could be.
I would like the new cam to sound good but alls be responsive - if int increases hp or more toruq well thats even better
here is what I do know I have in the car
350 ENGINE
HOLLEY SNIPER EFI CLASSIC GOLD FINISH
TURBO 350 AUTOMATIC TRANSMISSION
10 BOLT POSI WITH 3.31 GEARS
POWER STEERING
POWER DISC BRAKES
what type of cam would give me this sound and still be responsive with stock manifolds
if I need to upgrade to headers I have no prob doing that as well
I just know what set up would be good for stock 350
thanks
Adam Brown is offline
post #2 of 26 (permalink) Old Dec 8th, 19, 05:27 AM
Probationer
Rob
Re: new cams for 1969 350
Great question as I am in a similar situation without EFI. Can't wait to hear responses.
Steelhead56 is offline
post #3 of 26 (permalink) Old Dec 8th, 19, 07:18 AM
Vega$69's Avatar
You don't buy a cam for sound You buy a cam to optimize performance based on your build and the intended use of the engine,
To determine the cam that is best for your car you need to figure out what you have already. Do you have a roller or flat tappet cam? What is your compression ratio?
If your #1 goal is sound then I suggest you install some long tube headers. Will sound better then the sound you get with stock exhaust manifolds and give you a little more power
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 26 (permalink) Old Dec 8th, 19, 07:31 AM
Eric
John is right on the decision process. Also, considering you're running an auto trans with a stock converter you will want to stay away from cams that will hurt your drivability. My suggestion is taking a look at this Chevy Performance cam: https://www.summitracing.com/parts/n...make/chevrolet
It's a flat tappet hydraulic cam that's good for a warmed over daily driver and it will continue to work well for you as you add other improvements such as long tube headers. This is the same cam Chevy uses in their 350 crate engines today. https://www.gmperformancemotor.com/parts/3896962.html
1968 Standard Coupe, LS1, T56
2007 Tahoe, Z71, Cold Air & Tune
2001 Silverado, Z71, TSP Cam, Cold Air & Tune
really_n0b0dy is offline
post #5 of 26 (permalink) Old Dec 8th, 19, 07:39 AM
Just went thru this, 69 350 wanted good rumble, and not be soggy and have good low end and decent top end performance.
Went with towards rattler cam part number 118001-09. It gave me exactly what you are looking for. I also went with a little stiffer spring and 10 degree retainers number 98212-K12.
1969 Camaro LM1
chicoman is offline
post #6 of 26 (permalink) Old Dec 8th, 19, 07:45 AM
Vega$69's Avatar
The 109 LS on this cam is not very good when running a TH350 and stock TC. Would be better with 112-114 LS
The Rattler is Ok for a manual tranny.
Vega$69 is offline
post #7 of 26 (permalink) Old Dec 8th, 19, 07:48 AM
This cam gives me 13 inches of vacuum at 800 rpm idle, yes i have a 4spped, but with that amount of idle vacuum and a sniper efi , he should be able to tune and be ok with auto trans.
1969 Camaro LM1
chicoman is offline
post #8 of 26 (permalink) Old Dec 8th, 19, 07:52 AM
Vega$69's Avatar
With the TH350 his idle will need to be at 1000-1100 rpm with this cam. With the stock TC it will not work well IMO.
Best to call Comp and ask them for a recommendation
Vega$69 is offline
post #9 of 26 (permalink) Old Dec 8th, 19, 07:55 AM
OP
Very good advice given. You need to know what you have, flat tappet for full hydraulic cam now.
Cam and torque converter, if you have a automatic car, need to work in harmony. You generally install a higher stall TC with a larger performance cam as those cams start to make HP at a higher RPM than stock. Rear gears is also a factor to consider
Comp "Thumper" cams produce the kind of sound you may be looking for. Highly recommended you install new lifters with a new cam/ You will then need valve springs matched to the new cams lift and open & closed spring pressure requirements
one example of a Thumper cam
https://www.summitracing.com/parts/c...make/chevrolet
Headers for any motor will give a deeper exhaust note
SoCal805 is offline
post #10 of 26 (permalink) Old Dec 8th, 19, 07:56 AM
I agree a slightly loser converter would help him with this cam.
1969 Camaro LM1
chicoman is offline
post #11 of 26 (permalink) Old Dec 8th, 19, 08:05 AM
Brett
Adam, I think the point John is trying to make is the end result has many times a lot of underlying requirements to get to the desired end. In order to obtain the "Sound", if you just did one step (cam), it will actually make the performance worse. His suggestion of the long tube headers, which you are wanting to do anyway, will improve performance AND get closer to your desired sound.
John's (and other's) suggestion of laying out a plan and thinking things through has been a proven success and highly recommend.
If you want sound, do the long tube headers with a new exhaust and add cutouts. Then you could flip a switch and get all the rumble you want!
Good luck,
Brett.....
Rockets Up In 2020!
Brettallen59 is offline
post #12 of 26 (permalink) Old Dec 8th, 19, 08:05 AM
Vega$69's Avatar
And your are most likely running a different rear end ratio. The OP has 3.31.
There is no one size fits all for cams.
Something like this may work well.
Vega$69 is offline
post #13 of 26 (permalink) Old Dec 8th, 19, 08:18 AM
rear gear is 3.42, performer intake, @9.25 to 1 comp, holley 670 street avenger, 1 5/8 long tube headers, 4 speed. Howard recommmend 1800 stall with auto trans, but stock converter ok . Cam taken out was comp 262, this cam gives a little better all around performance, no loss in low end, comp cams 262 was i think a 110 lc, but the howards gives me what i wanted, great sound and good performance, i think he would be happy.
1969 Camaro LM1
chicoman is offline
post #14 of 26 (permalink) Old Dec 8th, 19, 08:22 AM
Vega$69's Avatar
The 262 is a 114
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #15 of 26 (permalink) Old Dec 8th, 19, 09:08 AM
The 262 is a 114
not always
1969 Camaro LM1
chicoman is offline
