Any interest in a modern leak proof vacuum relay for RS headlights? - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
post #1 of 9 (permalink) Old Jan 5th, 20, 02:16 PM Thread Starter
mccorry's Avatar
I've been frustrated with the leaking spools on the original and reproduction 1968-1969 RS vacuum relays. These are non-serviceable units that cause vacuum leaks which result in slow or impaired operation of the vacuum RS headlights in 1968-1969 models.
I finally worked around and found an alternative. It is an electrically fired (12V) industrial grade stainless steel spool with buna O-rings that is rated for full vacuum.
I left my factory RS relay in place and tucked the new unit under the relay to hide it, then routed the vacuum hose to the new MAC relay. I wired it to local ground and then the supply from the common hot wire off the brights switch (on the floorboard).
It works great, the lights operate quickly (as designed), and I don't have anymore constant vacuum leak to the engine.
Anyone interested in this? I had to buy a few relays to try and have a few left over to sell.
I'll post some photos later if there is any interest.
Steve -
'69 Camaro RS/SS-350, TH350, factory air, factory AM/FM, factory tilt wheel, console w/ gauges - Daytona Yellow
- 1969 Van Nuys Camaro Database
mccorry is offline
post #2 of 9 (permalink) Old Jan 5th, 20, 02:29 PM
Jeff
yellow69RS's Avatar
Re: Any interest in a modern leak proof vacuum relay for RS headlights
Not sure I'll be a buyer but would look at your modification if posted. I've never had functional doors on mine yet and probably two years away from having a need.
Jeff
yellow69RS is offline
post #3 of 9 (permalink) Old Jan 5th, 20, 05:03 PM Thread Starter
mccorry's Avatar
Here is a photo of the unit installed.... it is a MAC series 46 relay.
https://www.macvalves.com/product/46-series/
Steve -
mccorry is offline
post #4 of 9 (permalink) Old Jan 5th, 20, 05:14 PM Thread Starter
mccorry's Avatar
Steve -
mccorry is offline
post #5 of 9 (permalink) Old Jan 9th, 20, 01:18 AM
Garth
Interesting fix ! After shooting mine with silicone spray around 10yrs ago, inside the ports, haven't had any problems since. Worked well in the actuators too...
Garfields Maro is offline
post #6 of 9 (permalink) Old Jan 9th, 20, 07:48 AM
Ray
Very interesting Steve.
So looking at the pics;
The unit appears to be a four way spool and one port is sealed and not used?
Is the "override" on the OEM still used?
Since you used the low/high beam power feed, are those still operational? ...or can another power feed be used?
And is the RS light switch still used? Functional?
Maybe I'm not understanding how it operates...? I've included a diagram. Can you show or explain how it works?
I recently bought new hoses and I planned on getting my vacuum system up and running this winter. I'm using my original tank, "spool" valve, and a repop RS light switch. (I replaced the original one years ago due to electrical gremlins elsewhere)
Name:	69 RS Vacuum Headlight Diagram.jpg
'68 rs/SS 350 M-21 posi
numbers matching
rgwiz is offline
post #7 of 9 (permalink) Old Jan 11th, 20, 07:16 PM Thread Starter
mccorry's Avatar
All 4 ports on the spool are used. One is vacuum supply to the unit from the engine. One is a filtered fresh air Inlet to the actuators. The other two go to the front and back of the actuators. When vacuum is applied to the front, the fresh air is allowed to go into the back. Vice versa on the other direction.
The school is switched on 12 volt from the headlight switch. The stock vacuum relay still there, but doesn't do anything with the light covers. The 12 volt supply to the switch is off the common oh, so the doors are open with both standard and brights.
Steve -
mccorry is offline
post #8 of 9 (permalink) Old Jan 12th, 20, 08:42 AM
click's Avatar
Very cool job Steve.
click is offline
post #9 of 9 (permalink) Old Jan 19th, 20, 10:23 AM Thread Starter
mccorry's Avatar
Thanks, Jim. If no interest here, I might sell the other units on Ebay or something.
Steve -
mccorry is offline
