68 camaro floor and full rocker replacement - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 1Likes
  • 1 Post By bondora68
post #1 of 6 (permalink) Old Jan 15th, 20, 08:05 PM Thread Starter
Probationer
I am working on a 68 camaro. I have removed the floor in order to install new one piece floor. After getting the floor out i realized the rockers on both sides will need to be replaced. My question is will it be possible to reinforce the car and replace one ENTIRE rocker at a time or is there another way i should go about it? Any thoughts would be much appreciated.
Duda Mcstuffles is offline
post #2 of 6 (permalink) Old Jan 16th, 20, 06:15 AM
Tony
Re: 68 camaro floor and full rocker replacement
Build a body cart that supports the car in areas other than the rockers. Insure that nothing is going to move out of alignment once a rocker is removed. Have plenty of braces that mark the correct location of the new rocker. Spending lots of time in this kind of prep will make it go smoother.. I have mine supported by the frame rails and firewall in preparation for rocker removal...
Duda Mcstuffles likes this.
Tony
Follow my current Camaro project builds...
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
bondora68 is offline
post #3 of 6 (permalink) Old Jan 16th, 20, 03:14 PM Thread Starter
Probationer
Hopefully with any luck I can get to building the cart some time this evening. This is the first car Im building thats a unibody. It has me a bit intimidated, but once i can get the floor and rockers done i should be feeling pretty good about it.
Thanks for taking the time to reply, its very much appreciated.
post #4 of 6 (permalink) Old Jan 17th, 20, 08:47 AM Thread Starter
Probationer
will 1/8" wall thickness square tubing be sturdy enough?
post #5 of 6 (permalink) Old Jan 17th, 20, 10:28 AM
Yes, 1/8" wall is fine. The majority of the structure is with the tubing vertical.
It won't compress or deform.
my 67' build thread:
allanjs is offline
post #6 of 6 (permalink) Old Jan 17th, 20, 07:02 PM
Jeff
yellow69RS's Avatar
There are plans here for a body cart and it uses 1/8 inch wall. I spent about 400 for material to build mine, everything is cut but nothing is welded yet. if you are planning to cut both rockers off while having the floor out you need to brace it so you have the proper door opening when you're finished. If you put the floor back in before replacing outer rockers I don't feel the need to brace but other opinions vary.
Jeff
yellow69RS is offline
