Rally wheels - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 1Likes
  • 1 Post By KevinW
post #1 of 6 (permalink) Old Jan 17th, 20, 06:56 AM Thread Starter
Probationer
Rally wheels
Hi. New member. I want to replace my stock steel rims with rally wheels on 67 convertible. It does not have disc brakes and I don't want to do the conversion at this time. I want to stay with the 14 inch. I"m searching for used wheels but need a little help before making the purchase. 68-69 rally wheels appear to be different. My questions are:
1. Can I use a newer wheel
2. will the smaller flat cap fit the newer wheel
3. will the backing depth interfere with the turning ratio or cause tire rub
4. Can I use a disc brake wheel on a drum brake
5. Do you think the XG rally wheel will work
Thank you
Ron Bowen is offline
post #2 of 6 (permalink) Old Jan 17th, 20, 09:26 AM
Kevin
KevinW's Avatar
Re: Rally wheels
Ron, Funny! and Welcome! I want to do the exact opposite on my 69 Vert (drum brakes), swap out the XN rallys with some FC painted steel wheels
Here is a good read on Camaro wheels: Camaro Chassis - Suspension, Axle, Brakes, & Wheels
Your 67 could have come with 14x5 or 14x6 steel wheels or the same sized for Rallys (disc). The main difference is the rim contour. Disc rims have a different shape to clear the caliper then the drum version. So you can put a disc wheel on a drum car, but not a drum wheel on a disc car (Caliper will hit inside of rim).
1. All the "new" wheels are the disc profile, so not worries about using them on your drum 67.
2. The smaller flat cap with "inside" clips are designed to fit all 70's GM type rally wheel.
3,5. not sure what the backspace specs are, but the XG will work fine (68 Camaro disc 14x6)
4. Yes you can, see above
Not sure where you are, but if you are close to NJ, send me a PM
Kevin
KevinW is online now
post #3 of 6 (permalink) Old Jan 17th, 20, 10:31 AM
Garth
Re: Rally wheels
Click on the links, Ron. https://www.camaros.net/forums/20-ca...post1783188453
Bottom line, YES, the wheels are interchangeable and will work fine for your application.
Garfields Maro is online now
post #4 of 6 (permalink) Old Jan 17th, 20, 03:58 PM Thread Starter
Probationer
Re: Rally wheels
Thank you both for your help. You can't always be sure when you ask the seller if they'll work. I had a feeling most of the rally wheels would fit but no harm confirming it. Now I'll have to decide if the rally wheels are worth the investment.
post #5 of 6 (permalink) Old Jan 17th, 20, 04:02 PM Thread Starter
Probationer
Re: Rally wheels
Kevin, why would you switch the rallys for the steel wheels?
post #6 of 6 (permalink) Old Jan 18th, 20, 06:33 AM
Kevin
KevinW's Avatar
Re: Rally wheels
Ron, the rallys have been on my vert for 20 years, just looking for something different
R/T likes this.
Kevin
