67 Camaro - CPP Spindles, C6 Z06 Brakes, 17" Rallye Wheel. Questions! - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 1Likes
  • 1 Post By Vega
post #1 of 11 (permalink) Old Jan 20th, 20, 01:16 PM Thread Starter
Darko
Have a 67 Camaro and getting ready to install the CPP spindles that use the Corvette wheel bearing/hub, C6 Z06 brakes and want to put a Rallye wheel on it from Coker.
I want a 15x8 4.5" backspace with a 275/60/15 tire for the rear (I know this will fit), and a front wheel to match in a slightly larger diameter to clear the front brakes.
Questions:
1. Can I get away with a 17" wheel or do I need to go 18" to clear the brakes? I would prefer the 17"
2. The wheels can be bought with a 4.5" Backspace in 7" or 8" wide. Will that work? What is the biggest tire I can fit?
3. I know coker sells the Rallye wheels in different sizes. Are there any other places to get them? They are on backorder on almost all the sizes that are larger than 15"
darko is offline
post #2 of 11 (permalink) Old Jan 20th, 20, 02:01 PM
Vega$69's Avatar
Re: 67 Camaro - CPP Spindles, C6 Z06 Brakes, 17" Rallye Wheel. Questi
You will need 18Ē and the will need to be Big Brake cut wheels.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 11 (permalink) Old Jan 20th, 20, 02:04 PM Thread Starter
Darko
Can I get a rally wheel with the "Big Brake cut" option?
darko is offline
post #4 of 11 (permalink) Old Jan 20th, 20, 02:19 PM
Vega$69's Avatar
I donít know whatís available in a Rally Wheel.
I donít know if the make 18Ē steel Rallys. I believe they are made in an aluminum wheel.
Vision Wheels. Would need to verify will clear ZO6 brake caliper
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #5 of 11 (permalink) Old Jan 20th, 20, 09:41 PM
Nick
year one makes a 17" Rally Wheel, I don't know if the calipers will fit tho. Give them a call see what they say
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
post #6 of 11 (permalink) Old Jan 20th, 20, 10:10 PM
Chris
I have C5 Corvette 13" front brakes with a 17" wheel on my '69, but I don't know if the Z06 brakes/calipers you are asking about are larger than the C5 brake caliper/rotor combination I have. My wheels flare toward the hub near the outside of the spokes where they meet the hoop and this caused a slight clearance problem with my C5 calipers that could only be cured with a thin spacer. I'm assuming by "brake cut wheel" John is talking about a uniformly flat hoop with spokes that meet the hoop at 90 degrees on the inside of the wheel thus maximizing the clearance for the caliper. You will find a larger choice in tires with 18" wheels vs. 17" wheels, but wheel size is a personal preference and fitment decision. You're definitely not going to get those big brakes on a 15" wheel you mentioned.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #7 of 11 (permalink) Old Jan 21st, 20, 03:33 AM
Vega$69's Avatar
C6 Z rotors are 14Ēand the calipers are substantially larger than C5s.
Check on Protouring and LateralG to see what wheels guys are using. Most likely custom 3 piece like Forgeline for $5000 a set plus tires.
Thatís what I used on my 69 Protour car with C6 ZO6 brakes.
Vega$69 is offline
post #8 of 11 (permalink) Old Jan 21st, 20, 08:18 AM
Vega$69's Avatar
This is what it takes for C6 ZO6 brakes.
On my 69 Protour with 18" wheels.
See how the wheel spokes are designed to clear
130fe likes this.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #9 of 11 (permalink) Old Jan 21st, 20, 08:42 AM
Are you really wanting to run such a big mismatch between front and rear braking? I donít think that is a good idea imho...
What are you running in the rear? Drums or small rotor discs?
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #10 of 11 (permalink) Old Jan 21st, 20, 10:03 AM
Chris
130fe's Avatar
What are you going to use car for? Street, AutoX (probably not with those rears), drag?
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #11 of 11 (permalink) Old Jan 21st, 20, 10:18 PM
Chris
I realize you are wanting to use C6 Z06 brakes, but linked below is a thread from another forum discussing C5 brakes on a Camaro. Even though the thread is focused on C5 brakes, you might find some of the information useful for your project too.
https://www.pro-touring.com/threads/...r-67-69-Camaro
ctcz28 is offline
