4 link travel - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
post #1 of 5 (permalink) Old Feb 13th, 20, 12:39 AM Thread Starter
Apprentice
Miles
4 link travel
I'm fitting a bolt in 4 link similar to the ridetech. The shocks provided are Viking with 4" travel. The shocks are angled, so max travel is about 3". Springs are 250lb. Where should I be setting my ride height in the suspension travel? Around middle? That only leaves 1.5" before hitting the bump stops.
Miles B is offline
post #2 of 5 (permalink) Old Feb 13th, 20, 05:58 AM
Re: 4 link travel
Generally speaking you want your lower bars parallel to the ground and your shocks roughly centered in their travel at ride height.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 5 (permalink) Old Feb 13th, 20, 01:25 PM
Ken
Re: 4 link travel
which kit are you installing?
ktrim is offline
post #4 of 5 (permalink) Old Feb 13th, 20, 04:26 PM Thread Starter
Apprentice
Miles
Thanks Don. It just seems strange looking at the car from underneath that 1.6 inches or so is enough to absorb a big bump. I know the leafs had much more travel but they were also lower than 250lb.
It's the McDonald kit. A local company here in Australia. The Australian regulations apparently required a few little changes from the American kits, like angled shocks and both sides of the bottom eye must be gripped by the mount.
I actually didn't like a few things about their cradle so I carefully measured it and rebuilt it with fresh laser cut plate and thicker hollow bar. I'll work with my engineer to make sure it comes out legal.
Miles B is offline
post #5 of 5 (permalink) Old Feb 13th, 20, 05:41 PM
Vega$69's Avatar
Re: 4 link travel
4 Links and coil overs tend to be substantially stiffer and yield a harsher ride due to less travel. I would try to set them at about 60/40 so you have a little more down travel for the bigger bumps.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
