Nut/Bolt Finish Suggestions - Team Camaro Tech
Restoration Corner Where originality comes first
 3Likes
  • 1 Post By allanjs
  • 1 Post By allanjs
  • 1 Post By Craig1969
post #1 of 7 (permalink) Old Mar 10th, 19, 10:22 AM Thread Starter
Eric
Hi All, I'm ready to clean up and prep all of my front sheet metal hardware with the goal of trying to avoid what occurred in the picture. Current plan is to wire wheel the parts then soak them in Evaporust, then do a manganese phosphate coating like this:
https://www.duracoatfirearmfinishes....nt=39614861641
Most important to me is to not develop any unsightly surface rust over time, second is goal is to "resemble" the factory look in regard to color.
I'd like to avoid paints and having to oil the parts. Are there better processes I should be looking at?
Thanks!
1968 Standard Coupe, LS1, T56
2007 Tahoe, Z71, Cold Air & Tune
2001 Silverado, Z71, TSP Cam, Cold Air & Tune
really_n0b0dy is offline
post #2 of 7 (permalink) Old Mar 10th, 19, 11:19 AM
Tim
Re: Nut/Bolt Finish Suggestions
I suspect many on this site already know this or can comment good or bad but I watched a video on Youtube the phosphating treatment and one commenter suggested an alternative process of heating cleaned, used bolts/nuts/washers in an oven to 400 F and then dropping them in linseed oil. I happen to have an oven in my shop I have used for powder coating so I thought I would give it a whirl. Supposed to give the same black appearance as well as rust protection but I don't really know.
1969 Camaro - a gift from the brother-in-law build thread
Shannon4570 is offline
post #3 of 7 (permalink) Old Mar 10th, 19, 11:20 AM
You'll be ahead if you just buy new hardware from AMK. They sell all kinds of
combinations of kits. I went the phosphate route and just wasted time. You'll
run into some fasteners that will be too far gone to save.
really_n0b0dy likes this.
my 67' build thread:
allanjs is online now
post #4 of 7 (permalink) Old Mar 10th, 19, 01:38 PM
I re-zinc my stuff in a bucket, easy ,safe, and it keeps me entertained and off the streets
Did the seat base just because
rodent4 is offline
post #5 of 7 (permalink) Old Mar 10th, 19, 05:31 PM Thread Starter
Eric
Thanks for the insight on your experience. Was trying to save some cash on this, but think you're right.
post #6 of 7 (permalink) Old Mar 10th, 19, 06:56 PM
Eric, You can often buy the AMK kits cheaper through vendors. AMK has a
minimum requirement if you go direct. Just be sure you're getting AMK.
Some vendors are using other suppliers and the fasteners are not up to snuff.
post #7 of 7 (permalink) Old Mar 11th, 19, 07:51 PM
Craig
Craig1969's Avatar
Send a message via AIM to Craig1969 Send a message via MSN to Craig1969 Send a message via Yahoo to Craig1969
I use Boeshield T-9 on all hardware, including cast and aluminum. It comes in liquid can or aerosol spray. Never worry about discoloration or rust/corrosion. Do a Google search for Boeshield T-9.
Thanks!
Prepare to be the center of attention when you drive a first generation Camaro. You will be gawked at. Grown men & women will coo like children when you drive past. Children will scream like babies. Dogs & cats will get along. Does it get any better?
Craig1969 is offline
Guide to original parts finish and paint/plating specs ChuckD Restoration Corner 3 Feb 18th, 19 05:20 AM
Suggestions on fixing a top brace? dcaver Convertibles 5 Feb 7th, 19 06:33 AM
T56 Clutch & Pressure Plate Suggestions? really_n0b0dy Transmission & Driveline 17 Dec 11th, 18 11:28 AM
Windshield frame paint and finish DElsner Convertibles 3 Jul 16th, 18 11:02 AM
67 pillar post finish dc7432 Restoration Corner 6 Mar 21st, 18 06:33 PM
