Rear bumper holes - Team Camaro Tech
Restoration Corner Where originality comes first
 2Likes
  • 1 Post By allanjs
  • 1 Post By Sauron67MM
post #1 of 7 (permalink) Old May 16th, 19, 05:32 PM Thread Starter
Dale
Rear bumper holes
What is used if anything to fill the rear bumper holes that the bolts go through to attach bumper brackets? Is there something that will help seal or waterproof the hole.
Examples:
Rubber, silicone, plastic, putty
67 Camaro
Wigman87 is offline
post #2 of 7 (permalink) Old May 16th, 19, 05:41 PM
Steven
stamatisg1977's Avatar
Nothing that i know of
What u can do is get thin rubber sheets from home depot and u can poke the bolts thru that on the inside
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is online now
post #3 of 7 (permalink) Old May 16th, 19, 06:14 PM
Re: Rear bumper holes
I assume you're talking about the holes through the body. Strategically placed 3M strip caulk.
Commonly called dum dum.
Garfields Maro likes this.
my 67' build thread:
allanjs is online now
post #4 of 7 (permalink) Old May 16th, 19, 06:15 PM
3M Strip Caulk or duct sealant. You'll need duct sealant for the kick panels.
allanjs likes this.
Call for restoration and custom paint scheduling:
Sauron67MM is offline
post #5 of 7 (permalink) Old May 16th, 19, 06:54 PM Thread Starter
Dale
Would the 3M strip caulk be used on the outside?
1. Maybe putting a circle around the hole and letting the bracket tighten against it creating a seal.
2. Or does this product fill the hole and the bolt pushes through it.
67 Camaro
Wigman87 is offline
post #6 of 7 (permalink) Old May 16th, 19, 07:23 PM
scblucam's Avatar
I used blue RTV silicon back in late eighties.
68 302 M20 - 85 IROC Z
scblucam is online now
post #7 of 7 (permalink) Old May 16th, 19, 07:50 PM
Garth
#1 and some will do #2. Actually I applied it to the brackets prior to assembly, but probably doesn't matter.
Edit; You'll notice there's a square recess in the bracket for each body bolt to hold the sealant so it doesn't get squeezed out.
Garfields Maro is offline
Good Article rogerh Brakes, Suspension & Steering 6 Jun 3rd, 15 05:00 AM
Fiber-optic rear pod mounting holes daven1256 Body Shop 7 May 15th, 13 04:38 PM
69 rear Bumper Question canX11 Body Shop 2 Jun 2nd, 09 08:35 PM
How and where do rear bumper brackets attach to bumper? 1320King Camaro Tech 5 Feb 8th, 08 11:01 AM
Fitting of new rear bumper guards NORTHERN FRIEND Tech 2000 6 Sep 21st, 05 04:31 AM
