67 camaro am radio rear speaker - Team Camaro Tech
Restoration Corner Where originality comes first
post #1 of 8 (permalink) Old Jun 11th, 19, 06:18 AM Thread Starter
Chris
I am going for a 95% original restoration car and am at the final stages of the interior.
I have the jute mat and rear package tray going in and didn’t save any pics how the original am speaker was installed.
1. Does the speaker mount under the rear deck?
2. Do I cut out the rear package tray at the speak location, then install the original grill over top? Do the same with the jute?
3. What was the original am radio single speaker location? The car does have a fade option for the front speaker if that matters.
Thanks in advance.
Cmonson is offline
post #2 of 8 (permalink) Old Jun 11th, 19, 07:11 AM
Russ
Re: 67 camaro am radio rear speaker
Here's a few old threads from the CRG site with lots of detail. Also, if you have the 67 AIM see UPC U80 to see the radio connections.
U80 Package tray
U80 - Rear Seat Speaker
Petes L48 is offline
post #3 of 8 (permalink) Old Jun 11th, 19, 02:01 PM Thread Starter
Chris
Thanks for the response. Lots of good info for the dual rear speaker. I am actually looking for the single rear speaker information.
Cmonson is offline
post #4 of 8 (permalink) Old Jun 11th, 19, 02:56 PM
Ed
bertfam's Avatar
If you have a "fader", RPO U80 - Rear Seat Speaker, then you have two speakers. One under the dash and one in the package tray on the passenger side of the car.
Ed
Ed B. (but you can call me Bert!)
CRG -
bertfam is online now
post #5 of 8 (permalink) Old Jun 11th, 19, 03:43 PM
Russ
The AIM also shows the U80 single rear speaker on the passenger side of the package tray, just doesn't give a lot of detail.
post #6 of 8 (permalink) Old Jun 12th, 19, 08:30 AM Thread Starter
Chris
thanks for the input. I already mounted the original front dash speaker and am going to install the rear on the passenger side. The harness has the correct wire length for the passenger side as well.
Ironically both original speakers still work....
Cmonson is offline
post #7 of 8 (permalink) Old Jun 12th, 19, 09:48 AM
Russ
Sounds like you are using an original radio, so you should be fine. I believe modern radios have lower resistance and will burn out the original 8 ohm factory speakers.
post #8 of 8 (permalink) Old Jun 12th, 19, 04:54 PM Thread Starter
Chris
Correct - I am using the original am radio.
Cmonson is offline
